RatchetRake or BXpanded Piranha Toothbar-BOTH
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #11
John - Why didn't you just buy another Kubota so you could have one with a RR?
Or the cheaper solution (assuming you have QA) would be buy another bucket with a RR, think how many minutes you could save in swapping! :)
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #13
Here's me ratchet raking and other stuff just this past weekend:
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #14
No answer.
Like I said earlier and in another post where I put up some pics, I had been using it to grade my road and rip out some potholes. Maybe used 1/2 dozen times before it was basically 3/4 worn out and at that point it was scrap metal. As I said, its fine for light duty homeowner stuff...scratching into soft dirt or other loose material...but far too light duty for anything beyond that.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #15
Wow, thinking your talking about some off-brand type?????!! I can't imagine wearing out 1/2" thick steel after 6 uses. :shocked:
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #16
yep no way
maybe if he strapped it to a bulldozer's blade but that ratchet rake will probably outlast any compact tractor
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #17
I posted pics here before.. 6x it was toast and it was a original RR...trust me.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #18
I think that is the confusion... I thought you were talking about a PTB.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #19
I don't know what a PTB is, but mine was a ratchet rake. I bumped another similar thread from years ago when I had mine. The pics are there. ...Like I said, it's probably a fine homeowner tool for loam, weed overgrowth, light grading etc.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #20
Piranha Tooth Bar
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A58018)
2007 FREIGHTLINER...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
