RatchetRake or BXpanded Piranha Toothbar-BOTH
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #11
John - Why didn't you just buy another Kubota so you could have one with a RR?
Or the cheaper solution (assuming you have QA) would be buy another bucket with a RR, think how many minutes you could save in swapping! :)
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #13
Here's me ratchet raking and other stuff just this past weekend:
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #14
No answer.
Like I said earlier and in another post where I put up some pics, I had been using it to grade my road and rip out some potholes. Maybe used 1/2 dozen times before it was basically 3/4 worn out and at that point it was scrap metal. As I said, its fine for light duty homeowner stuff...scratching into soft dirt or other loose material...but far too light duty for anything beyond that.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #15
Wow, thinking your talking about some off-brand type?????!! I can't imagine wearing out 1/2" thick steel after 6 uses. :shocked:
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #16
yep no way
maybe if he strapped it to a bulldozer's blade but that ratchet rake will probably outlast any compact tractor
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #17
I posted pics here before.. 6x it was toast and it was a original RR...trust me.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #18
I think that is the confusion... I thought you were talking about a PTB.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #19
I don't know what a PTB is, but mine was a ratchet rake. I bumped another similar thread from years ago when I had mine. The pics are there. ...Like I said, it's probably a fine homeowner tool for loam, weed overgrowth, light grading etc.
   / RatchetRake or BXpanded Piranha Toothbar-BOTH #20
Piranha Tooth Bar
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
Deere 310L (A53317)
Deere 310L (A53317)
2015 Ford F-550 (A55973)
2015 Ford F-550...
golf cart (A56859)
golf cart (A56859)
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
