Ran 3320 out of fuel. Won't run.
   / Ran 3320 out of fuel. Won't run. #11
Your John Deere is self priming. Just keep trying to start it as it may run/stop/run/stop several times before it stays running. It's a Yanmar engine
At least that is what I've done twice now that it ran out of fuel. My issue (at least my excuse) is the fuel gauge shows almost 1/4 tank when in fact it is on empty.
Should say that in your manual.
   / Ran 3320 out of fuel. Won't run. #12
If one elects to loosen injector line at injector be sure to keep fingers clear from spraying diesel fuel. Diesel injected under skin will require serious medical attention. I agree with beenthere that one should check manual for correct instructions. Photo from operators manual below states model 3320 is self bleeding
   / Ran 3320 out of fuel. Won't run. #13
Everything is self bleeding if you crank for Long enough...
Anyway, watch a video or two before doing the bleeding process, it's not hard, or that messy, and not dangerous, but you only loosen the line until you get air then diesel coming out, that's part of why a 2nd guy/gal is useful; you don't want to completely remove the line/nut. And it's all better understood visually than with text.
Once you are running again, it might stutter and bog for a minute or two; but if it runs funny for longer than that, you likely need to replace filter, or drain a sediment or water separate bowl.
   / Ran 3320 out of fuel. Won't run. #14
If the machine Truly ran completely out, vs it still had some fuel in the filters and all, but cut off once, or started to die and OP shut it down, cranking until it fills filters, purges lines of air, and all that, that's could be a Lot of cranking, like 2 or 3 minutes if cranking; which is hard on a battery, and starter.
   / Ran 3320 out of fuel. Won't run. #15
paulsharvey
It's a Deere, not a Kioti. ;););):)
   / Ran 3320 out of fuel. Won't run. #16
Bleeding at the injectors would be the last step and only if needed. First bleed to the fuel shut-off, then work your way to the injection pump. Up to this point, you can use gravity, the lift pump (key on), or a manual lever pump to bleed. Then, with fuel bled to the injection pump, IF it doesn't start, you may have to bleed the injectors.
   / Ran 3320 out of fuel. Won't run. #18
The process is the same in a 4.5L 3 cylinder deere or a 1.8L Kioti, or a 14L V12. Some have a manual hand pump to push fuel to prime, and then there is less air to purge; others dont (or frequently, the hand pump doesn't work...). It's generally not awful, unless you have a lot of trash in the system, or ran till stall, and restarted multiple times. Often the worst part is doing all this with a weak battery to make it all more fun.
Generally, the filters and pump aren't sucked completely dry, and with a 2nd hand, it's just an annoyance, and a lesson learned. When it starts starving for fuel, shut her down and refuel.
   / Ran 3320 out of fuel. Won't run. #19
I know it is splitting hairs, but if you shut down just before it starts starving for fuel it would make it even easier, lol. Or better yet... Check your fuel when you check the oil before you start it each morning? While I don't fuel it ever day, I do check to make sure I have sufficient fuel to run thru the day or I start planning on when I will stop work to go fuel the tractor up.
Getting in the habit of watching the fuel level will make life a lot easier when you own a diesel engine!
I can only imagine the damage, as slight as it is each time a pump is sucked dry of fuel, since most of them are lubricated by the fuel that they pump.
David from jax
   / Ran 3320 out of fuel. Won't run. #20
I ran a buddy's Ford 555 backhoe out of fuel in my youth. We struggled to bleed that son of *****. I've been keeping one eye on the fuel gauge ever since...
Lesson learned
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2014 Ford Explorer AWD SUV (A55853)
2014 Ford Explorer...
2019 Bobcat E32i Mini Excavator (A55851)
2019 Bobcat E32i...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
