Ramp strength
/ Ramp strength #1
rimshot
Platinum Member
Michigan
Kioti CK2510 HST
I have a CK20 by Kioti with a FEL and Backhoe. That rig weighs all of 4000 lbs and I haul it on a 7000 # car trailer which is brand new by Continental Cargo. (please see attached pics.
I'm nervous about these ramps. I don't see a rating on them and they bowed quite a bit when the tractor was equipped as seen in pics but less backhoe which was replaced by snowblower. When it was equipped with snowblower, the rig weighed about 700 lbs less. Now I have replaced snowblower with backhoe so more weight up and down these ramps.
I have tried putting a stiff leg in support of middle of ramp to try to add strength but that does not work so well. Funny things happen when the ramp flexes and it sometimes actually either pushes truck and trailer forward or ramp rearward. I don't think that is the right approach.
Please note the construction of these ramps from picture showing bottom. They are heavy steel but is it heavy enough for this heavy tractor. The ramps are designed to slide in a couple of storage areas on side of trailer so I hate to go any thicker or longer. As it is and you can see by the picture they are reinforced with a square tubular steel piece which measures 1 1/2" outside. Basically, they are 70" in length.
Any thoughts or comments? Does this seem like enough beef. If you want any additonal measurements please inquire. Thanks for any comments in advance.
rimshot
/ Ramp strength
Here is one more picture
/ Ramp strength #3
rimshot
You need to block the rear of the trailer so it cannot lift the tow vehicle when you are loading.
/ Ramp strength
trying that extra picture again
/ Ramp strength
Perhaps it is as simple as that.
thanks Kevin
rimshot
/ Ramp strength #6
Could you chock the trailer tires and maybe add a piece of metal to the underside of your ramps, that should solve your problems and also set the parking brake on the truck and trailer hitches are designed for down force, not up force, be careful
/ Ramp strength #7
Your ramps do not appear to be built heavy enough. They look more like an atv ramp. A welding shop could probably brace them up for you. Even if you put a jack stand under your trailer to ease the load on your hitch, it will not stop the ramps from flexing. JC
/ Ramp strength
I think I agree with all the suggestions provided. Thanks to all who chimed in. I was thinking of perhaps beefing the ramp up with a 1 1/2 or 2" Angle Iron welded alongside. The only thing is, these things are already very heavy and they need to slide into those pockets beneath the trailer deck. They were proovided by the trailer maker of my Continental Cargo trailer for cars and as recall some of those old Packards or Cadilacs could weigh as much as 5000 lbs
Today, was a test run so I blocked up to the bottom of the tail end of the trailer as suggested. I then went ahead and loaded the Kioti with the chocks shown in the first set of pictures I submitted under the ramps for support. I stuck them under the ramps at mid span on the ramps. It worked very well and with the support provided and if I make it a point to use them I believe it is pretty strong.
I will most likely use a couple of jack stands under the rear of the trailer permanently from now on.
Thanks for the helpful suggestions.
rimshot
/ Ramp strength #9
rimshot
One other thing...............The cars you mention only have one tire on each ramp as you load. The tractor is short enough you may have the whole load on the ramps as opposed to only half of it.
/ Ramp strength #10
Holy Pete, though...look at that backhoe! You end up with so much of the tractor's weight over the rear tires it isn't funny! As the BH slides rearward, it creates a moment that pulls the entire center of mass from the front of the tractor to the rear...as it slides rearward, the rear tires have a proportionally higher ratio of the load. Though the backhoe weighs only 700# on paper, the net effect by compounding the moment against the rest of the tractor probably adds a lot more than 700# to the rear wheels of the tractor. Of course I'd have to do some calculations...
If it were me, I'd look into some type of "folding" brace. You could make it out of relatively thin material since your strength would come in the width. If you hinge it against the box-sections that are already there, you could have them nest inside the existing ramp and fold down (they would be straight down...perpendicular to the top of the ramp) when you use the ramps. They could be triangular...narrow toward the front of the ramp and a solid 9 or 10" tall at the center of the ramp. But make them out of 3/32 steel...or 3/16" aluminum even. You could brace them against each other in the center once standing.
You can add all the 1-1/2" steel angle you want...you'll still have an awful lot of flex.
That's my thought.
/ Ramp strength
That's my thought.
Actually it is even heavier than that. The CK20 hoe weighs in at 1100 lbs. i believe the use of those center chocks are the easiest fix. With those in place the ramp becomes very sturdy.
rimshot
/ Ramp strength #15
One drawback to folded ramps that don't easily detach- if you need to haul something long that could hang off the back you have a problem. IOW with a long car or truck the trunk or bed can't hang out the back or the folded up ramps will hit it. They also add unneccesary wind resistance when towing empty...one of my smaller trailers has a full width expanded metal gate that when standing up feels like it might as well be solid, it can fold all the way over into the bed of the trailer though when empty- the difference in perceived feel of wind resistance is substantial.
/ Ramp strength #16
I have a degree in aerospace and know a lot about drag. A mesh gate actually has more drag than a solid piece of wood/steel the same dimensions. The reason for this is what is called "parasite drag" In simple terms all the little holes in the mesh give more surface area for parasite drag to create the drag where as a solid piece would only make the drag around the edges once under way.
Chris
/ Ramp strength #17
Couldn't have said it better myself. Also, the ramps are typically shorter when they're the fold down variety than the pull out. This makes loading low vehicles very difficult.
The ramps are also difficult to slide on their mounting shaft once it has been used a bit and the shaft isn't as straight as it once was.
/ Ramp strength #18
thanks all.
Diamond pilot, that's very interesting. Thanks for sharing that. I love the random stuff I learn here.
Does that mean that attaching a piece of sheet metal to stand up ramps will improve gas mileage?
/ Ramp strength #19
What Mr. Diamondpilot is suggesting is that the aggregate effect of a whole bunch of little bitty low pressure areas pulling back on the cheese grater ramps while in travel are HIGHER RESISTANCE than the effect of one big fat low pressure area pulling back on, say, a SOLID ramp (no holes...plywood).
I concede the point that the cheese grater ramps have an ENORMOUS amount of wind resistance, I'd need to see data confirming it is, indeed, more aggregate drag. Wouldn't attach the plywood to save gas just yet. But if you did, you probably wouldn't notice much of a difference one way or another...
I further concede that it would be GREAT to be able to fold down the heavy duty ramps shown on Mr. Blk88GT's trailer, but I am certain they produce FAR less drag than the landscape style mesh steel (cheese grater) ramp. I'd be hard pressed to say you could feel the wind resistance from those over the actual weight of the trailer, especially when loaded.
/ Ramp strength #20
Keith is right. The cheese grate type is the ones that kill you with the drag. My wifes uncle runs a trucking company on the Indiana Illinois state line and they travel once a day to Columbus Ohio. His fleet consist of 20 or so Semi trucks, 5 or so F-150 Long bed 2 wheel drive trucks, and 2 20' tandem axle trailers that are identical except one has a fold up mesh gate.
One Christmas we were all sitting around talking guy stuff and taking each others money playing cards. He was telling us that one of his trailers had a problem and he could not figure it out. He said he had all new running gear put under it including tires but could not figure out why it could only make it to Indianapolis behind one of the companies F-150's when the other trailer could get back to the state line with a few gallons to spare. He told us he even took it to a alignment shop to make sure the trailer was straight. I asked him if it was the trailer fold up gate. He said yes. I told him it was the gate and his response was it has holes in it.
Long story short he took the gate off and it now gets the same results as the other trailer. The mesh gate was making the truck get about 10-15% worse fuel economy at highway speeds hauling the typical 6,000# load.
Chris
