MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,150
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Why don't you get two pieces of angle iron the same length as each ramp and weld one under the length of each ramp right down the center?
An angle iron, or L beam, adds considerable strength and not much weight. It will still allow you to slide the ramps into their storage sleeves and you won't have to carry jacks around for the ramps.
Your current ramps do not appear to affix to the trailer, but rather, they hang on the trailer. If you are not on level ground, or the ground is soft under the end of the ramp, and you put jack stands under the ramps in the middle of them, you could create a teeter totter (SP?) condition. When you hit the end of the ramp, it could go down, causing the ramp hangar to lift out of the channel in the rear of your trailer. Just something to think about.
