Ram 1500 EcoDiesel
/ Ram 1500 EcoDiesel #61
That can't be true. I read that the ecodiesel didn't' have enough payload to haul the family and camping gear, let alone do real work pulling a trailer.
Congrats on the new truck! Hopefully it's SEC tough. Congrats on the Texas Bowl LOL. I fully expect there to be an aggie search committee formed to contact Chip immediately.
/ Ram 1500 EcoDiesel #62
Towed the 16' livestock trailer with two full grown horses. I estimate about 7K lbs. Truck did great. I was worried that the rear end would squat but it did not and it towed fine.
Been getting 22 mpg overall and easily 24-26 hwy.
Glad to hear your new truck is working out for you,enjoy.
/ Ram 1500 EcoDiesel #64
The Ram ecodiesel would have been an option except that I needed to pull 12k pounds. My F150 would pull better than 7k, but I had to go to a more powerful truck. That was a shame as I had driven that F150 for 16 years up until that point. I had thought that the Ram used a Cummins engine until I read the recent specs. Did Ram change engines?
/ Ram 1500 EcoDiesel #65
The Eco Diesel uses a Fiat based in house engine. For now the 2500 series and up still use Cummins but my bet is in the next 3 years they will also go to a in house Fiat engine.
/ Ram 1500 EcoDiesel #66
In Sept. 2015, my wife replaced her dying GMC with a RAM ED1500. It has been pretty much trouble-free and hauls a 2-horse trailer well. I wish we had the OEM adjustable air shock bags in it, since it squats a bit when loaded up for a horse show, but it does as well towing as the GMC (with small V-8) did and gets lots better mileage. Hauling the horse trailer on the highway, the GMC used nearly 25 l/100km (of gas), whereas the RAM's diesel consumption when hauling the horses is only a bit over 13 l/100km.
The DEF tank lasts about 10k between refills, so it isn't too much of a hassle, either.
If we did a lot of hauling (or heavier hauling), I think we'd have gone for a RAM hemi or possibly a Ford EB. Since most of our driving is just toodling around, without a load, we like the fuel efficiency of the RAM ED and it is a really comfortable truck to ride in.
Well my better half told me that the truck was getting 20 mpg towing our two horse trailer. I wanted her to reset the mileage for the trip counter to see what it got but of course she did not :laughing:.
She said the instant was showing 20 on flat ground.
/ Ram 1500 EcoDiesel #68
I found when I test drove the ED that the computer display was actually reporting worse mileage than actual. ( numbers similar to my Hemi, which I knew were wrong for the diesel )
Thought I would keep this thread updated. Looks like it's getting about 18 mpg all time driving, which is significantly better than what my ecoboost got unloaded. We're pulling a two horse trailer several times a week, probably 6-7K lbs. I hand calculated it at 17.8 which is about what the dash shows (within .2 mpg). It's hard to give a figure on what it gets unloaded since we tow with it so much.
2500. Going to put air bags in the rear to help with towing.
/ Ram 1500 EcoDiesel #72
Not sure if you are a member of, or visit, the forum RAM 1500 Diesel Forum, but there is a lot of air bag experience documented there. Seems the most popular are Timber Grove and TLC. I'm no expert on the subject, but have read many of those threads, and I believe both of those companies offer setups with and without compressors. Timbrens also seem to be a popular option. Timbrens are bump stops, and a cheaper option to air bags. that seem to help with sagging and many members of that forum use them and like them. Seems like you tow a lot, so air bags are probably the better option and well worth the extra money for your situation. Just a few options for you to consider as you research.
I hit 6,700 miles on my Ecodiesel yesterday on a trip to Morgantown and back. Lifetime MPG is just over 23 according to my fuelly app. The more I drive this truck, the more I like it!
I'm not a member at the 1500 diesel forum but I've been reading it a lot.
I'm thinking about going with the air lift 1000. I don't need a lot of lift, just maybe 2 inches. I'm probably not going to install on board air. I'm gonna put the 1000 series bags in for minimal cost and start with 5 psig.
One thing that worries me is on some of the bags you remove the factory springs. I'm not real clear on it. What happens if one of those bags fails??
/ Ram 1500 EcoDiesel #74
You probably need a weight distribution hitch.
/ Ram 1500 EcoDiesel #75
That's a good question and one I don't know the answer to. I'd have to hear a pretty good argument for getting bags that require removing the factory springs. I plan to go with a 100% bolt on option when I'm ready.
I also don't plan on getting on board air, as I don't want to give up space to a compressor and tank for something I will not use often.
Good luck and keep us posted on what you end up with.
/ Ram 1500 EcoDiesel #76
The air bags just support and supplement the factory springs and usually replace the bump stops.
/ Ram 1500 EcoDiesel #77
I had these on my 2014 Ram. They work very very well.
When you install them, the spring has to be in full droop, no weight on the tire at all. I used a large wooden spoon to work the bag into the spring. I would wait until some warm weather to do it, or bring it inside a heated garage. The bags are pretty stiff when they are cold.
/ Ram 1500 EcoDiesel #78
That's the answer. Per RAM, WDH for trailers over 5000lbs. That would eliminate the rear sag and give you better handling up front too.
Since I know nothing of WDH can someone explain what the difference is and recommend a brand?
70-80 degrees almost all winter here in S tx. :thumbsup:
Caterpillar TL1055D (A62177)
Caterpillar...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
14in Bucket w/ Teeth Excavator Attachment (A64194)
14in Bucket w/...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
2022 EZ-GO ELITE...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
