Rake grapple able to pull brush out of the ground?
   / Rake grapple able to pull brush out of the ground? #11
Another Ratchet Rake recommendation.
   / Rake grapple able to pull brush out of the ground? #12
The buck-thorn that we have is very tough and deep rooted.I had about ten acres cleared with a SS and FECON head(this after ten years numerous tractors and bush-hogs).That worked well,we now maintain with the tractors.
After clearing;we plowed up and put into food plots.
   / Rake grapple able to pull brush out of the ground? #13
I don't know if anyone has mentioned already but, what about cutting the roots with a stump bucket? Most have a blade between the digging teeth. Once they are cut, the rake grapple should move them just fine.
   / Rake grapple able to pull brush out of the ground? #14
Might be that a multi-tine ripper would pull the roots and vines. I have only Buck brush. 1/4" in diameter - two feet tall. Stands up straight as a telephone pole.
I use my root grapple on this stuff. Wide open grapple - grab as much as I can - pull straight up and rip out of the ground. Shake it to get rid of dirt - then onto the burn pile.
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
2011 John Deere 5085 70HP Utility Tractor (A55973)
2011 John Deere...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
