raising 3pt hitch..
/ raising 3pt hitch.. #1
psuedofarmer
new hampshire
Kioti DK55 Cab, 3 NHs (from 40-90HP)
i'm apparently doing something wrong..
hooked up the log splitter this morning - had no trouble raising/lowering the 3 pt hitch. after using it for an hour, i decided to take a break, so i went to lower the 3pt hitch so i could rest the splitter on some cinderblocks.
now the 3pt hitch won't raise.
according to the manual (which by the way, STINKS), the draft position should be @ shallow, then raise/lower the hitch..
let the tractor sit for a few minutes to cool down (had been running for a few hours).. still no luck.
any ideas on what i'm doing wrong?
pf
DK55c (w/39 hrs)
/ raising 3pt hitch.. #2
Check the 3PT drop/raise speed control located near the floor in front of the seat. Also check if one of the rear remote levers is stuck in other than neutral or center position. The draft control unless using it should always be in the full forward position full down
/ raising 3pt hitch.. #3
Did you add hydraulic fluid to compensate for the fluid the wood splitter consumed?
Don
thanks for the quick reply.
tried adjusting the speed - slow/fast, then in-between. not quite sure what the 'neutral' setting is on the rear 3pt hitch drop/raise level - but with the draft full forward (deep), and with more hydro fluid (it's just above the minimum - should probably add more), still no luck.
no change. still will not raise.
pf
just checked the hyrdo fluid - it's at the absolute low end of the range. will add to bring it up.. good idea!
if i'm registering fluid level @ the absolute low end of the range i would guess that it would still raise..(?). going to put more in right now.
(would you belive i'm in the cab right now?)
pf
added enough to bring the hydro level up to within range.. 3pt hitch refuse to move. i noticed that the draft control is set to shallow - but even when i work both controls the 3pt hitch doesn't budge.
thanks for the help!
pf
/ raising 3pt hitch.. #7
Maybe some air in the lines? Try moving the tractor around, use the hydraulics/FEL to circulate the fluid.
<font color="blue">(would you belive i'm in the cab right now?)
</font>
You could be "computertechnofarmer" /forums/images/graemlins/smile.gif
Don
/ raising 3pt hitch.. #9
Make sure the quick connects are indeed connected fully. Try disconnecting the splitter altogether and see if that makes any difference.
When you hooked up the splitter, did you need to change the lever on the valve block diverter, or are you using remotes? I know on my CK20, which uses the main valve block for the backhoe, I have to move a lever on the valve block to divert fluid that way. If it's not in the proper setting, the loader won't move. I suspect there is something that needs to be adjusted. The 3pt hitch speed control wouldn't keep it from lifting, only dropping. Good luck and let us know. John
/ raising 3pt hitch.. #10
On one tractor here the spring on the draft control is inside the housing, while the levers that control the lifting is outside. This spring the 3ph would not raise no matter how much we fiddled with the lever. Got a mechanic out to look at it and the rod that goes through the housing was rusty and wasn't letting tha draft drop back to raise the arms. In your case maybe the spring is broken. The offending parts are tucked in between the lever and the housing, the one part that wasn't moving had a roller on the end that rode against the part connected to the lever. Might be worth checking out since you're right there anyway.
/ raising 3pt hitch.. #11
"not quite sure what the 'neutral' setting is"
Middle setting for the rear remote levers. They have a detent on them to hold them open if they are held open the 3PT will not rise. They are the 2 Grey levers right side of the seat.
<font color="blue"> Middle setting for the rear remote levers. They have a detent on them to hold them open if they are held open the 3PT will not rise. </font>
bingo.
while i thought the setting was correct - it wasn't. it 'looked' llike it was @ the right setting, but i played with the settings and now it raises normally.
thanks convert (and everyone else).. i'm back to splitting wood!
i've got LOTS to learn.
neat thing is, i ran into this issue and had it resolved without leaving the cab! this forum is amazing.
pf
/ raising 3pt hitch.. #13
Glad I could help. So how far are you from an access point and still getting connected.?
<font color="blue">So how far are you from an access point and still getting connected </font>
assume you mean to internet?
i live in a rural area, so the best high speed option is via satellite. once the signal is in the house, i run a wireless router that my laptop is able to access. in this case, i'm pretty close to the house (about 150 ft) so the wireless router has no problem.
it's an amazing setup - with today being a fine example: couldn't get in touch with the dealer, so posted a question to the forum; you (and others) provided immediate feedback, allowing me to get back to cutting wood for the winter (lost time @ this time of the year is a bad thing).
now, if i knew tractors like i knew technology, i'd never be in trouble.
thanks again for the help!
pf
King Kutter II Tiller for sale.
King Kutter II...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
FULL SIZED PORTA POTTY (A60736)
FULL SIZED PORTA...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
