I have a gravity feed 500 gallon diesel tank on tip of a 7 ft stand and just got a used gasoline 12v pump 500 gallon gasoline tank on a steel tube sled.
I'd like to change the gasoline tank to gravity feed... paint it white, label it gasoline then place the tank below the diesel tank on same stand and eliminate the 12v pump and the sled.
What is recommended for proper safety setup?
Can both tanks be on one stand? Are venting or a pressure relieve valve required /recommended and what about grounding?
TIA
TIA
