Rairoad Ties For Retaining Wall?
   / Rairoad Ties For Retaining Wall? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
I saw there is another retaining wall thread and thought of adding there, but the purposes seem too different.
I need a short wall about 3 feet high on one side and close to 20 feet long. The other side would "L" off at 90 degrees and taper from that 3 feet down to nothing. I though about concrete block, but there is a significant cost for a few hundred blocks and mortar and I'm not very good at that kind of masonry. The current wall is just treated 2x8s stacked and held with fence posts. It has done the job for several years but is now leaning and bowing quite a bit as expected. It held lot longer than I thought it would though.
I could re-do that, but the purpose is changing and I want the new wall to help form two sides of a storage shed. So, I thought about railroads ties that I can buy for $10-15 each. I would stack them so the ends are staggered to help interlock them Maybe drill holes and drive re-bar through them. The dirt side would be lined with a couple of layers of 4 or 6 mil plastic. I'd add a few 4x4 posts on the 'inside' which would both reinforce the ties and support the roof section.
Thoughts?
   / Rairoad Ties For Retaining Wall? #2
Buy the nicest ties you can find, and it could last 20-30 years. My father and I both have/had RR tie projects. His wall is falling apart now. Still straight and doing its job, but the back fill of gravel is starting to fall through holes here and there. While I like the idea of plastic, you really ought to let it drain. Backfill with gravel, and if you're going to use plastic sheeting, add pipes to remove the water.
   / Rairoad Ties For Retaining Wall? #3
Oh, and he had metal "straps" that ran vertically at the interior posts. Large bolts ran through the metal, through the tie, and into the posts. The straps acted as large washers so the bolts didn't pull through the ties over time.
   / Rairoad Ties For Retaining Wall? #4
Thoughts?
Pre-bore holes in the ties, and use cut pieces of 1/2" re-bar for spikes.
Hold each row of ties an inch back from the top leading edge of the row below.
Consider constructing with a very slight inward tilt to the wall.
Be generous using "dead men".
Backfill with any type of coarse/permeable material.
Do not use plastic.
You do not show a location in your profile, so we do not know if frost will be an issue.
As mentioned: Buy the best quality used ties that you can find.
   / Rairoad Ties For Retaining Wall? #6
Although not as high as yours (3 courses of ties max), I had success with mine. I needed to prevent erosion under the maple w/o upsetting oxygen to the roots so I backfilled with coarse bark and topped off with chips. After a year the maple is fine. My ties were crappy - I had to insert bolts thru them to hold them together, so as said before get good ones.
   / Rairoad Ties For Retaining Wall? #7
My wife wanted to do a landscaping project using used RR ties (Home Depot and Menards sells them) but when she discovered the issues with using creosote treated RR ties she back away from them and went with ties made from recycled and composite materials.
Googling the subject will bring back information like this;
Landscaping with Railroad Ties | HGTV
   / Rairoad Ties For Retaining Wall? #8
From what I understand, RR ties can be cut from almost anything, so you really have no idea what type of wood is used. Here in East Texas, it's any hardwood that is big enough to be cut into a RR Tie. That doesn't mean that's what's available here because they are shipped all over the country, and then back again. But it does meant that you have no idea what you are using when you buy them.
The Railroad installs them on top of rock that allows the best possible drainage. They have to be kept off of the dirt to last.
Here in East Texas, lots of people use them for landscaping. I think they look nice when installed, but once they are in contact with the soil, the bugs find them. They start eating away the wood from the bottom so you never see it. Over the years, more and more wood is eaten away until all you have left is the part you see. Then one day, you touch it wrong, or there is a big storm, or you touch it with the mower, or whatever it is,and the wood just crumbles. Ten years seems to be about average.
I would never use RR Ties for anything.
If it's a small retaining wall, the cost of blocks isn't that much more. Do it once and be done with it.
   / Rairoad Ties For Retaining Wall? #10
I would use pressure treated, 6"x6"x8' landscape timbers.
CAT CS563 (A47477)
CAT CS563 (A47477)
Sky Trak 10054 Legacy 10K Telehandler (A54865)
Sky Trak 10054...
CAT D6C Dozer (A47477)
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
KUBOTA L3700SU TRACTOR (A54756)
KUBOTA L3700SU...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
