Rainy day fix
/ Rainy day fix #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
I copied this from another post on TBN, solution for soot on loader arms. It worked but the poprivets that hold it on would vibrate loose, so I fixed it.
/ Rainy day fix
This is the old part after I removed it, just a short length of 3/4" copper tubing and a 45 degree fitting and steel poprivets
/ Rainy day fix
Here's the new part, these are on the BX22 Kubota, don't know why they weren't on the 2200.
Priced that part at my local dealer, (are you setting down) $48.00. I came by it as part of a deal for the BX grill guard at another dealer.
/ Rainy day fix #6
What works good for getting off soot after its there. My pressure washer(2850 psi) doesn't touch the stuff. Tried spraying soapy water and letting it sit from the pressure washer as well...nothing.
Suppose I need to use Simple Green and wipe it off?
/ Rainy day fix #7
<font color="blue"> Suppose I need to use Simple Green and wipe it off? </font>
That is what I use.
/ Rainy day fix
I used GoJo handcleaner, smeared it on and used a brush, I didn't leave the soot on the arms very long, don't know how hard it would be to get off after it set.
/ Rainy day fix #10
Try a little deisel fuel on a soft rag, then wipe off the area with a soft dry rag, then wash with soap/water. Works great for road tar too. Wont hurt the paint either, and really makes it shine for a while.
DT
/ Rainy day fix #11
WD40, the modern snake oil miracle!!! Supposedly cures arthritis too, but that's debatable.
/ Rainy day fix #12
I also use Simple Green and no wiping. I just spray on let sit a couple minutes and pressure wash off......done /forums/images/graemlins/grin.gif
/ Rainy day fix #13
I was at Lowe's a few months ago and they were closing out gallons of Simple Green. When I asked why, they showed me the display of the new Simple Green. They changed the formula and it is now "safer"???? /forums/images/graemlins/confused.gif Has anyone tried the new formula????
/ Rainy day fix #14
No but tried the old bottle I've had sitting around for few years. Works good.
10ft Fork Extensions (A66734)
10ft Fork...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
Hay Van BL-96 3pt Hay Grabber (A64912)
Hay Van BL-96 3pt...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
Steiner TL348 50in Rotary Tiller Tractor Attachment (A64553)
Steiner TL348 50in...
