radio interference
/ radio interference #22
88 ;)
/ radio interference #24
i figured you'd get a kick out of that.. :)
/ radio interference #26
I am no hammer, but let's 30 the 88's unless he's a she :)
I left the 88 in jest as it looked like the poster huffed off after i mentioned his minimalistic approach to a fix was going to also yeild minimal results. i think he expected the revelation that he was a ham would full quiet the channel as if none of us else might be hams.. engineers.. or had radio propogation theory, or communication experience / electronics experience. :)
didn't want him to go away mad .. so left a good 88 to his 73's :)
/ radio interference #28
I see i was correct in my assumption. I rest my case :) ;)
/ radio interference #30
i think he wants me to QRT :)
/ radio interference #31
a few things you can do.
1, run an 'L' or a 'PI' filter
2, use carbon core 'supressor'wires and not oe style metal core spark plug wires.
3, use resistor plugs.
the latter 2 have spark intensity issues.. so if the L or PI filter handles the job.. I'd forgo the secondary resistors.
a L filter is an inductor (choke) inline with the power wire, and a single filter across power and ground(after inductor ).
a pi filter is the inductor in the power wire, and a capacitor across the power to ground both ahead and after the inductor.
I'd use a high farad value capacitor.. at LEAST 1000UF if not higher like 2200UF .. heck.. i've made filters for police cars with hi output alts back in the day, that used 4700uf and even 6800uf capacitors in a PI setup.
also.. a large value inductor will yeild beter results than one with lower 'henries' i'd reccomend 300uH minimum
for S&G's you could put a torrid core in the power distro too.
google choke input filter and capacitor input filter for more info.
ignore references to any butterworth filters
soundguy
Whatever!
I would go with a strillium enufricator ....with a 6 pin phremastat....... in line.;).
I had ham for lunch er... ah ....breakfast.
/ radio interference #32
what.. no flux capacitor? :)
/ radio interference #34
north!
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
Rhino HPHD (A64127)
Rhino HPHD (A64127)
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
1999 Volvo Sleeper (A62613)
1999 Volvo Sleeper...
