radio interference
/ radio interference #22
88 ;)
/ radio interference #24
i figured you'd get a kick out of that.. :)
/ radio interference #26
I am no hammer, but let's 30 the 88's unless he's a she :)
I left the 88 in jest as it looked like the poster huffed off after i mentioned his minimalistic approach to a fix was going to also yeild minimal results. i think he expected the revelation that he was a ham would full quiet the channel as if none of us else might be hams.. engineers.. or had radio propogation theory, or communication experience / electronics experience. :)
didn't want him to go away mad .. so left a good 88 to his 73's :)
/ radio interference #28
I see i was correct in my assumption. I rest my case :) ;)
/ radio interference #30
i think he wants me to QRT :)
/ radio interference #31
a few things you can do.
1, run an 'L' or a 'PI' filter
2, use carbon core 'supressor'wires and not oe style metal core spark plug wires.
3, use resistor plugs.
the latter 2 have spark intensity issues.. so if the L or PI filter handles the job.. I'd forgo the secondary resistors.
a L filter is an inductor (choke) inline with the power wire, and a single filter across power and ground(after inductor ).
a pi filter is the inductor in the power wire, and a capacitor across the power to ground both ahead and after the inductor.
I'd use a high farad value capacitor.. at LEAST 1000UF if not higher like 2200UF .. heck.. i've made filters for police cars with hi output alts back in the day, that used 4700uf and even 6800uf capacitors in a PI setup.
also.. a large value inductor will yeild beter results than one with lower 'henries' i'd reccomend 300uH minimum
for S&G's you could put a torrid core in the power distro too.
google choke input filter and capacitor input filter for more info.
ignore references to any butterworth filters
soundguy
Whatever!
I would go with a strillium enufricator ....with a 6 pin phremastat....... in line.;).
I had ham for lunch er... ah ....breakfast.
/ radio interference #32
what.. no flux capacitor? :)
/ radio interference #34
north!
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2015 John Deere 332G Skid Steer w/ Bucket (A63688)
2015 John Deere...
