radiator cap part #
/ radiator cap part # #1
robert421960
Rockholds Ky
2014 Kubota L3301
ive got a farmpro 2006 2425
can someone give me a number for a crossover cap so i can buy one at a local parts house?
/ radiator cap part # #3
Seriously?
If anyone could it would be Diamondpilot.
I'm going to bet you will get quicker satisfaction by just taking in your cap and have them match it up. It's what they do.
/ radiator cap part # #4
My father was VP of Stant and had over 40 years with them but he retired 2 years ago.
I think the number Tommy gave is a good one. You want a low pressure cap. 7 psi is what I have on mine.
Chris
thanks for the help guys
i got the stant one you gave me the number for
/ radiator cap part # #9
Yeah, the Stant 7 psi cap is a good choice. OE is even lower (3-4 psi), but they're junk. Closest aftermarket cap you'll get is the standard 7 psi agricultural/off-road cap. A 15 psi automotive cap will sooner or later lead to seepage
//greg//
/ radiator cap part # #10
Well, in defense of Keno, y'all know that water (say coolant) boils at a much higher temperature when under pressure (it's called Gay-Lussac’s Law). I have had the 15# Stant cap on my dozer since day one, and run a 190° thermostat for thermal efficiency. I am also over 250 hrs. on the lube oil, and it is perfect.
/ radiator cap part # #11
I see this is an old thread, but when searching Google for a radiator cap on my 2000 Nortrac 254, it referenced this post. Just wanted to inform people that the older "Jinma" tractors use a smaller 7# radiator cap. I found that a NAPA #703-1418 fit just fine. Not sure what year they switched to the larger Stant #10228, but in 2000 they were using the smaller cap. Just my 2 cents.
2015 Grasshopper 725D 72in Zero Turn Commercial Mower (A68183)
2015 Grasshopper...
2017 Ford Transit 150 Cargo Van (A66736)
2017 Ford Transit...
1997 FRAC TANK 500BBL WHEELED (A68842)
1997 FRAC TANK...
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2013 WACKER NEUSON  TLN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
