Rabbit Speed
/ Rabbit Speed #1
caspers62
Bobcat TC 5600D/Long 510DT
I have a 08 5600D and the high speed has quit working, everything else is working. Work mode works, when I push the button on the travel selector handle nothing lights up or switches. I have checked the switch itself and it seems to be working. Any ideas???
/ Rabbit Speed #2
You've probably already done this, but you might have some error codes stored. IIRC that little card in the cab has the procedure for accessing the codes. I think you hold down the headlight button...but I don't recall for sure.
/ Rabbit Speed
I'll have to check that. Thanks
/ Rabbit Speed
There are no error codes. It read "none" .Still digging into it.
/ Rabbit Speed #5
Don't know why it would stop working if it was before, but look at the control panel setup (page SA-6 in the operation manual) under two speed set up.
/ Rabbit Speed
That was it, don't know how it got turned off but going into that section and basically rest it to where it should be. The two speed works!! Thanks
Cummins 6-Cylinder Diesel Engine with Transmission (A61568)
Cummins 6-Cylinder...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2024 John Deere 408R Sprayer (A63109)
2024 John Deere...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
set of 4 tractor trailer tires Roadforce (A63118)
set of 4 tractor...
2004 Electric Club Car Cart (A61569)
2004 Electric Club...
