Rabbit Speed
   / Rabbit Speed #1
caspers62
Bobcat TC 5600D/Long 510DT
I have a 08 5600D and the high speed has quit working, everything else is working. Work mode works, when I push the button on the travel selector handle nothing lights up or switches. I have checked the switch itself and it seems to be working. Any ideas???
   / Rabbit Speed #2
You've probably already done this, but you might have some error codes stored. IIRC that little card in the cab has the procedure for accessing the codes. I think you hold down the headlight button...but I don't recall for sure.
   / Rabbit Speed
I'll have to check that. Thanks
   / Rabbit Speed
There are no error codes. It read "none" .Still digging into it.
   / Rabbit Speed #5
Don't know why it would stop working if it was before, but look at the control panel setup (page SA-6 in the operation manual) under two speed set up.
   / Rabbit Speed
That was it, don't know how it got turned off but going into that section and basically rest it to where it should be. The two speed works!! Thanks
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
3in Poly Pipe (A49461)
2008 INTERNATIONAL DURASTAR 4300 SERVICE TRUCK (A50854)
2008 INTERNATIONAL...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
