R4's cracking
/ R4's cracking #1
Ridgewalker
Platinum Member
St. Francois Mountains of Missouri
NH TC29
I recently noticed that my rear R4's are starting to crack around the lugs in the center of the tires.
Has anyone ever tried to repair the cracks? If so how did you do it? TIA
/ R4's cracking #2
The local tire shop here, les schwab, call those cracks "torque cracks". Depending on the age of tire or severity of the cracks, usually not much can be done. Generally, they can go pretty long if the rest of the tire is good shape in normal service. Long as your not pushing, pulling heavy loads and running over obstacles constantly and making the tires spin, they should last a long time. Only real fix is replacing the tire.
/ R4's cracking #3
So is the problem with the rim or tire????
/ R4's cracking #4
It would be with the tire for the problem. A little less traction or stress would help them last longer.
/ R4's cracking #6
Up here we call that "sun cracking" and while we might try to park in the shade a little more there is nothing that can be done (so we are told).
Back when I worked in service the rubber suppliers would tell us that all the strength was in the cords, whether it was belts or tires.
Of course back before that as a kid at the service station the boss pointed out that we could always get a sale of a new fan belt by pointing out the cracks on the inside of the belt (to customers that we didn't like)....
/ R4's cracking #7
I've seen some severely cracked tires just keep on a going, keeping tires out of the sunlight when not in use will go a long way in the life of a tire.
2019 GENERAC MDG75DF4 TOWABLE GENERATOR (A63276)
2019 GENERAC...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
Rooster (A64557)
Rooster (A64557)
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
