R4047
/ R4047 #21
Don't mind Tom Seller, he's just a useless troll who isn't capable of making worthwhile, non inflammatory posts.
As for the EZ shift, there are very few numbers that use one. I have not heard any rave reviews about it, and my dealer won't even stock them because he is not a fan of the system.
Having owned a shuttle shift before, I really don't see much benefit to adding the EZ setup.
I have had a 4041ez for two years now - I have had very few problems with it but at around 200 hours (have about 280 now) I had some minor issues (a electronic module that needed to be replaced) with the ez shift. These were well taken care of by LS and the dealer (all under warranty).
/ R4047 #22
After owning it for awhile, do you still find the EZ system as a helpful add-on? I never used it myself. ..
What situations do you find it most useful?
/ R4047 #23
To be honest, other than only pushing a button to shift - thus perhaps saving my clutch and leg muscles a bit - it has been pretty good. Funny - this was an advantage in the winter (when it was minus 40) when I couldn't move my leg because it was frozen!! :) ... but when I am bush-hogging and need to change speeds often (depending on where & what I am cutting) it has been pretty handy as well. To me, it has been useful at times (and I am used to it now), but not necessarily a deal breaker. The other thing to keep in mind is my rig is babied! :)
/ R4047
Thanks guys. How hard was it for you to get use to the ez. I mean did you have to think oh I have this in order to use it. If I had to think about it I would probably just hit the clutch out of habit. Main reason I am not keen on a hydro.
/ R4047 #25
You get used to it. .. quicker than you'd think. Each of my 3 tractors have been slightly different in that regard, you really do learn it quickly.
/ R4047 #26
At the beginning it took a little time to get used to - but I still use the clutch at times ... because I can! :)
/ R4047 #27
I think the best part of it is being able to go from forward to reverse without clutching. I don't really use the push button.
/ R4047
Ok so how often do you actually do that? I have found with hydro reversers that the delay is too lang when using it for loader work. Like when loading a trailer with dirt or litter or hay even I roll into the trailers. Is it still that way with the ez.
/ R4047 #29
Not trying to sway you, but that is one of the best things about HST, no lag and you're less likely to run into stuff. You can move fractions of an inch per second, and it will stop moving the second you ease up on the pedal.
/ R4047
My fear with them is how well they hold up. I am one that uses a foot throttle a lot I set a gear and min rpm mainly for hydraulic speed and use foot throttle to control speed during project. Unless it is something that requires pto speed then I just set and go. I do use a disk and ground drive rakes. I have seen on here that they are not good in ground engaging uses. Why?
/ R4047 #31
I don't think it's that they're not good in ground engaging work, but you put more power to the ground with gear. You always run consistently lower RPM's with gear because hydro loves RPM's. I usually keep mine around 1800-2000 most of the time. That gives me enough power to the wheels and enough hydraulic pressure for a smooth loader.
/ R4047 #32
I use my MF pretty much the way you describe (it's a gear tranny). I set the throttle for min RPM, and then use the foot throttle as I work (except when using the PTO speed).
I think TSO nailed it on the issue with hydro. It's mostly the loss of HP that people dislike, not that it doesn't work well with ground engaging implements. My LS has 47hp and only 38.5hp at the PTO. My MF has 48hp, but 45hp at the PTO. In some situations, that extra 7hp at the PTO might make a difference. If you're working a large field with a tiller, the hydro really doesn't help you any...you're setting the RPM, picking a gear, and pretty much leaving it there. If you're doing loader work, it's a big difference in efficiency.
I have one of each, and I'm glad I have both, but there are a lot of times when I can see the utility of the HST...even brush hogging, or mowing....you can back up that little bit to catch an area you missed, etc. With a gear setup, that's just too much trouble, so you wind up making another pass, or partial pass to get it, and that wastes some time. Still, if my neighbor gets one of his tractors really stuck, I'm getting my MF with that extra power and R-1s on it to pull him out.
Then again, I'm pretty sure I could justify having 5 or 6 tractors all set up slightly differently :D
/ R4047 #33
forgot to speak to this too. .. I don't think that at this point, there's anything to worry about with the HST not holding up. You don't see many posts forum wide with people wearing out HST transmissions, especially LS forums.
They're pretty durable nowadays.
/ R4047
Thanks guys. Gives a lot to thanks about. Think I still want gear drive. Something about know that steel
Is involved when I get in a hard pull.
/ R4047 #35
Gear drives are good. A shuttle operates a loader just fine. A Hydro is a little better IMHO, but not the end of the world if you don't have it.
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
Carpet Cutting Table (A65579)
Carpet Cutting...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
2011 Kenworth T400 Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
