R4041/R4047 engine question
/ R4041/R4047 engine question #1
Gaharley03
McDonough, GA
1956 Ford 640, 2014 LS R4041, 1947 Ford 2N
The LS specs list the engine as a S4QL though I cannot find any info on this engine. Is it the same as a S4Q2? Hopefully someone is in the know.
/ R4041/R4047 engine question #2
No, the S4Q2 is smaller, and puts out around 38-39hp (it's used in the R3039). What do you want/need to know about the engine?
/ R4041/R4047 engine question #3
S4L2 in the R3039.
Search for Mitsubishi engines. I found the complete spec sheet on a Mitsu website. Sorry, did not save the link.
Bob
I am looking at new tractors and comparing and just can't find any info on the S4QL engine. New holland lists the Boomer 40 and 50 engine as S4Q2 on their website. So I was trying to verify if they are indeed the same engine.
/ R4041/R4047 engine question #5
I just looked at the NH site, and they list the Boomer 35 as having the S4L2 engine, which is correct....1.7L/107 cubic inches or so. The Boomer 40 and 50 are the larger 2.5L/153 cubic inch engine.
My 4047 has the larger of the two, and it's a very nice running engine. It's smooth, powerful, and starts easily, even well below zero (F).
Cool thanks then based on the New Holland site I'll assume that the S4QL in the LS and S4Q2 are the same engine possibly renamed because it is built by LS.
GManBart I see you have an 8N listed in your signature how does the R4047 compare size wise?? I know it has a lot more power and weight. Reason I ask is I have a 56 600 series and like the size but don't want to go much bigger if any.
/ R4041/R4047 engine question #8
Ok the S4L2 was the 3039 engine the S4QL was the larger 4041/4047 4 cylinder engine if I am remembering right. The S4Q2 engine according to the Mitsubishi web site is the tier 4 equivalent 4 cylinder engine for the 4041/4047. Depending on the Yxxxxxxxx number after the S4Q2 it comes as a 33.5HP, a 46.4HP, or a 48.5HP engine. This has been my question, if Mitsubishi has a tier 4 compliant engine why did LS go to the Shibaura engine?
Engine Series Inquiry
It is my understanding that LS went with the tier 4 Shibaura engine over Mitsubishi due to cost.
/ R4041/R4047 engine question #10
I am considering purchasing a 3039 with the s4l2 or the 4041 with the s4Ql-d. anyone know what the d after the s4ql means and also are they both good engines?
Unless your dealer has a R3039 on the lot they can't get them anymore or so I'm told. I think the S4QL-D is essentially their "de-tuned" version because the 4047 has the S4QL engine as well. I'm sure someone smarter will correct me if I'm wrong.
/ R4041/R4047 engine question #12
That makes sense. They have a r3039 but can not get the r3039h. I was wondering how the 4041 and the 4047 had the same code s4ql but different HP rating.
Thanks for the reply.
/ R4041/R4047 engine question #13
You know, it's interesting, but if you remove the FEL, the two are very similar in size. The wheelbase is nearly identical, and the overall length is 12-15" longer for the LS, but I'm not sure how much of that is the grill guard. They are similar in width, but the LS is taller, and has much larger tires, so it looks way bigger. In this pic you can get an idea...the Massey is bigger than the LS (around 5" longer wheelbase, much longer hood, etc).
/ R4041/R4047 engine question #14
Great comparison!
Eugene
Thanks. The R4041 seems similar size to my Ford 640 though I have a grille guard on mine. I signed the paperwork on a new R4041 so I'll give a comparison to my 640 when I pick it up. I'm having them put a detent kit on one of te rear remotes. BTW nice tractors.
/ R4041/R4047 engine question #16
If you notice, the mitsu engines LS was using in previous model years and currently in the G series; are all labeled interm tier 4. Last years documentation shows them as tier 3. It is the same engine. They made the switch as someone else stated due to cost. They are allowed to sell up to 50% of interm tier 4 models if they were made in 2013. Same for the phase in period starting in 2014. Here is a chart put out by the EPA and the emission standards that must be met. Nonroad Compression-Ignition Engines -- Exhaust Emission Standards | Emission Standards Reference Guide | US EPA
/ R4041/R4047 engine question #17
No I didn't see that (interim) on the status column, or at least I didn't pay any attention to it. Is that what it means then that is real good information. I guess it's something like Dodge, that have always used Cummins diesels and still do in their 3/4 and 1 tons but when they put the diesel in the new 1/2 ton they when with a different manufacturer because fiat owns the company and the engine was already in production but same thing to save money.
/ R4041/R4047 engine question #18
Congrats!
Thanks. Looking forward to enjoying it
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
Kubota L2501 (A62177)
ARTS WAY PM25 FEED MILL GRINDER MIXER (A63291)
ARTS WAY PM25 FEED...
