R&B Mfg. at it again, need testers
   / R&B Mfg. at it again, need testers #1
RBManufacturing
Riverside, MIssouri
Ford 8N / Kubota B 6200. Kubota B 7100. Modified wards lawn tractor. Souped up.
Hi Guys, It has been a long time since we posted. I do read TBN sometimes, But
we have been busy and not had much time. We have developed a new inclinometer
that is designed to attach with strong magnets to the blade of a dozer, or grader.
We have a model that reads in percent, (model # 18PR) and a model in degrees
(model# 10DE). They are large enough to see from the cab. I would like to have
a few guys with dozers, or graders to field test them. Anyone interested? I will
supply the model free, and only request feedback in return. You may keep the model.
I will send one to the first 4 people to request one. Some of you may remember that we
did this with a few other models in the past. You may post your opinions here.
Interested testers contact me through e-mail at "RandBMfgInc@worldnet.att.net."
Thanks, Rick
Welcome to R&B MFG. INC
   / R&B Mfg. at it again, need testers #2
I received my new lighted title meter from Rick yesterday. I had to do an oil change to the car last night so I didn't get a chance to install it, but I did some scouting for a location to mount it. It is looking like the double sided tape method to the top of "firewall" will be my best bet. Hopefully I can get this installed tonight or Friday and start reporting my results.
Thanks Rick!!!
   / R&B Mfg. at it again, need testers #3
I got mine, too, yesterday. I'm looking at a location off the loader valve support. I should have it on this weekend ready for action.
   / R&B Mfg. at it again, need testers #5
I also got mine yesterday, but no extra time was in the box!
   / R&B Mfg. at it again, need testers #6
Got mine installed tonight. It is wired up to the factory headlight switch. I used the double sided tape that Rick provided and stuck it to the top/front of the dash after I wiped it down with rubbing alcohol. Not sure if the tape will continue to hold or not. I may end up having to drill holes.
So far I like the mount. A lot of versatility in how it can be adjusted to fit almost any angle. Rick put lots of LEDs in the sucker, it is bright.
Now the bad part, a couple of the spots I'm used to going to are actually around 16 degrees. Now all of a sudden I keep hearing that "tractors can go 15 degrees and be safe":eek: I guess the good thing is, my tractor doesn't even feel tippy at the level.
   / R&B Mfg. at it again, need testers #7
Too many variables to make a flat statement that "tractors can go 15 degrees and be safe" or any other number of degrees. For tractor alone, no implements or attachments, on a smooth hard surface, I've heard 20 degrees. I've mowed at 18 degrees, but maybe I scare easier than some:D because I started moving slowly and carefully at 10-12 degrees, and got uncomfortable at 15 degrees. You have to remember, especially on a small tractor, that one little hole in the ground on the low side, one stick or rock on the high side, can make a big change in the angle real fast.
   / R&B Mfg. at it again, need testers #8
I know, the reason I said that, is I've read that a bunch of times on this site. I still consider myself a noob since this is my first tractor and I've had it 6 years, but I always thought the tractor felt "tippy" now when I realize at what kind of an angle I actually am at, I think the tractor is pretty stable for its size.:)
   / R&B Mfg. at it again, need testers #9
I would like to hear how the meters work. I HATE working my tractor on a side hill. Even a small angle makes me uncomfortable. I worked for a man when I was a kid helping with his hay. First day of work all was well. showed up the next day and he was dead from a roll over.
   / R&B Mfg. at it again, need testers #10
I'm a fan of the R&B meters in general, though I just have the old school one. I'd love to get one on my grader blade though
2003 Land Rover Discovery 4WD SUV (A59231)
2003 Land Rover...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
