Quirks I live with
   / Quirks I live with #41
And naturally, recently they've worked flawlessly without any extra effort.:laughing: I think they like cool weather.
Bird, about 14 years ago I had similar problems with round fluorescents in my kitchen fixtures in my Grand Prairie, Tx house. I decided to do an experiment when I noticed they seemed to not work during periods of peak power use. I checked the input power from the power company and found they were dropping voltage to reduce power consumption. Some days I had power coming to my house that was only 102 volts. As soon as the voltage went back up to 108 or above, the fluorescents were not a problem.
   / Quirks I live with #42
That makes sense, Jim. I used to keep a volt meter plugged into one of the outlets in the RV because low voltage can damage some things.
However, after I said the lights have been working OK recently, then yesterday, 7 came on and one did not. I tried the trick with the broom to no avail. But flipping that one switch off and back on brought all the lights on.
So, just now I went out there, flipped both switches on, 3 lights on the north bank came on, none of the south bank. Current voltage was 222. I flipped the south bank switch off and back on; nothing happened. Flipped the switch off and on once more, and all 4 came on. Flipped the north bank switch off and back on 4 times; same 3 light came on each time and one did not.:confused:
   / Quirks I live with #43
That definitely qualifies as a quirk :confused2:
JB.
   / Quirks I live with #44
And a short time later, I went back out there, flipped both switches on. All the south bank lights came on, 3 of the north bank. The same one did not come on. But I walked out back, got the lawnmower from the garden tool shed, brought it into the shop, plugged in the battery charger on it, then flipped the north bank light switch off and back on and all the lights came on.:confused:
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
1299 (A58374)
1299 (A58374)
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
