Quick question
/ Quick question #1
PutnamVictor
Can I use a bolt with an O-ring to plug up a port on a valve? It had straight threads with an O-ring fitting on it.
Thanks!
/ Quick question #2
Thanks!
Possibly. If you have a bolt that is the exact same thread, and IF the head is big enough.
But why not just buy the right $2-$3 plug and be done. Thoes o-ring fittings have machined surfaces, and I dont think the underside of a bolt is.
/ Quick question #3
Thanks!
You have a BSP thread on this valve, which is British Standard Pipe Thread
that goes along with the O ring. Its not a good idea to try to substitute a regular bot for this seriously.
/ Quick question #4
leonz,
With all due respects, he did not mention anything about the brand of valve, How did you know what valve he was talking about?
/ Quick question
"But why not just buy the right $2-$3 plug and be done."
It's more about the time than money.
Thanks.
/ Quick question
Less than $4 including shipping for 2 from dillspot.com. Just have to wait for it now.
Again thanks for the input. :thumbsup:
/ Quick question #7
if it is a 3/8 orb style valve.. a 9/16 bolt and oring should do it.. however.. what I have done for later use is get a orb to JIC fitting, and a JIC cap. put the orb fitting on and cap .. if you later need that port, you can simply get a jic hose to mate up to it without much fuss and muss at the valve.
soudnguy
/ Quick question #8
leonz,
BSP is real UNcommon around me. all the ORB style valves I've used recently are straight bolt thread ...
soundguy
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
HARDEE GATOR TAIL PTO PUMP (A63291)
HARDEE GATOR TAIL...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
2004 John Deere 4720 (A60462)
2004 John Deere...
