Quick question
/ Quick question #1
PutnamVictor
Can I use a bolt with an O-ring to plug up a port on a valve? It had straight threads with an O-ring fitting on it.
Thanks!
/ Quick question #2
Thanks!
Possibly. If you have a bolt that is the exact same thread, and IF the head is big enough.
But why not just buy the right $2-$3 plug and be done. Thoes o-ring fittings have machined surfaces, and I dont think the underside of a bolt is.
/ Quick question #3
Thanks!
You have a BSP thread on this valve, which is British Standard Pipe Thread
that goes along with the O ring. Its not a good idea to try to substitute a regular bot for this seriously.
/ Quick question #4
leonz,
With all due respects, he did not mention anything about the brand of valve, How did you know what valve he was talking about?
/ Quick question
"But why not just buy the right $2-$3 plug and be done."
It's more about the time than money.
Thanks.
/ Quick question
Less than $4 including shipping for 2 from dillspot.com. Just have to wait for it now.
Again thanks for the input. :thumbsup:
/ Quick question #7
if it is a 3/8 orb style valve.. a 9/16 bolt and oring should do it.. however.. what I have done for later use is get a orb to JIC fitting, and a JIC cap. put the orb fitting on and cap .. if you later need that port, you can simply get a jic hose to mate up to it without much fuss and muss at the valve.
soudnguy
/ Quick question #8
leonz,
BSP is real UNcommon around me. all the ORB style valves I've used recently are straight bolt thread ...
soundguy
Land Pride BB1260 (A62177)
Land Pride BB1260...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
Woods BB72 72in Rotary Brush Cutter Tractor Attachment (A61567)
Woods BB72 72in...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
Margaritaville Mini Decorative Truck (A61569)
Margaritaville...
