Quick question
   / Quick question #1
PutnamVictor
Bronze Member
Can I use a bolt with an O-ring to plug up a port on a valve? It had straight threads with an O-ring fitting on it.
Thanks!
   / Quick question #2
Thanks!
Possibly. If you have a bolt that is the exact same thread, and IF the head is big enough.
But why not just buy the right $2-$3 plug and be done. Thoes o-ring fittings have machined surfaces, and I dont think the underside of a bolt is.
   / Quick question #3
Thanks!
You have a BSP thread on this valve, which is British Standard Pipe Thread
that goes along with the O ring. Its not a good idea to try to substitute a regular bot for this seriously.
   / Quick question #4
leonz,
With all due respects, he did not mention anything about the brand of valve, How did you know what valve he was talking about?
   / Quick question
"But why not just buy the right $2-$3 plug and be done."
It's more about the time than money.
Thanks.
   / Quick question
Less than $4 including shipping for 2 from dillspot.com. Just have to wait for it now.
Again thanks for the input. :thumbsup:
   / Quick question #7
if it is a 3/8 orb style valve.. a 9/16 bolt and oring should do it.. however.. what I have done for later use is get a orb to JIC fitting, and a JIC cap. put the orb fitting on and cap .. if you later need that port, you can simply get a jic hose to mate up to it without much fuss and muss at the valve.
soudnguy
   / Quick question #8
leonz,
BSP is real UNcommon around me. all the ORB style valves I've used recently are straight bolt thread ...
soundguy
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
MONITOR WITH BUILT IN COMPUTER (A53843)
MONITOR WITH BUILT...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2008 BMW 535xi AWD Sedan (A53424)
2008 BMW 535xi AWD...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
