Quick mount
/ Quick mount #1
Svendus
Sweden
Yanmar YM2020D
Quick mount on a Vteks V2a front end loader
New custom made bracket max 500kg 1 102.31131 pounds
/ Quick mount
Be leave me
A Vtek V2K loader has 200 mm c / c dimensions of the bucket attachment
the Quick bracket we got the c / c 170 mm dimensions which result in bent shafts on tilt pistons in fully raised position of the loader
I'll tryed if I can direct piston rods and after 2 hours careful work with our small 10 ton hydraulic press we made it straight again :duh:
Here's a link to 6 photos in my Dropbox:
https://www.dropbox.com/sc/n6lin21j9wht1l3/HdkIufR9xt
/ Quick mount #3
Did you make the bracket, that is some really nice work. I hope it all works out for you.
/ Quick mount
Thank you,
yes the brackets are homemade from 8mm steel
The Quick Mount are Vtek. The Duch dealer will send us new pistonrods
and he will try to find right size Quick Apdapters.
/ Quick mount
We drilled new holes in the Quick mount
and now it functions to tilt the tools mounted the loader
Still waiting fore new replacement Tilt Cylinders :cool:
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2014 Ford Explorer (A62613)
2014 Ford Explorer...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
