Snow quick mount
/ quick mount #1
gmbracing
Acworth, NH
kubota bx25
How do I keep the shaft in the front mount from moving foward. It doesn"t have flats for the set screws, It sure does bend the pto shaft when it comes apart!!
/ quick mount #2
How about a model number/tractor size to better answer your question.
For what it is worth... On my QH (L2180) for a L3130 tractor the snowblower side has a 1/4" key with set screw plus a 1/4" pin. The PTO is married to the blower. On the other end the housing needs to be pulled back so the locking balls can be release to slide over the splined shaft.
The set screw does not lock on the shaft, but on the key.
/ quick mount #3
It does not need flats. Be sure it is in the proper position and tighten the set screw up good and tight.
My guess it that whoever assembled it at the dealer forgot to tighten them up!!!!!!!!!!!!!
There should be NO end pressure on that shaft. If there is it is not put together properly.
/ quick mount
THanks, I'll tighten them up good then replace the pto shaft Ouch!!
/ quick mount #5
You do have the manuals, right???? If not, get them from the dealer, the shaft has a specific location and is measured off the sub-frame and varies for different tractors.
/ quick mount
I have the manuals and will use the correct measurements
Winpower PTO Generator (A66408)
Winpower PTO...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
Sea Ray 170BR Speed Boat (A66408)
Sea Ray 170BR...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
New/Unused 20x30 All Steel Carport (A65583)
New/Unused 20x30...
3098 (A63117)
3098 (A63117)
