Quick MiG question
/ Quick MiG question #1
Erik Graham
Toronto, Ontario
Kubota B2630,Ford NAA, Kubota L2550GST
Greetings;
I hope this is an appropriate place to ask this question. Like many other posters I've been mulling over which size and type of welder to buy for a while and have narrowed it down to something like the Millermatic 180. There is one thing I'm not entirely clear on though. If I use flux core wire can I get away with not using any sheilding gas? If this happens to be true, the second question would be, would this weld be as strong as regular wire and gas, given that all the variables are the same? Main use of welder would be indoor, mild steel, 3/16" to 1/4". Any input greatly appreciated.
Cheers, Erik
/ Quick MiG question #2
If you use flux core wire, no sheilding gas is needed. I prefer regular wire and gas. The main advantage I can see to flux core is if using outside where the wind blows the argon mix away. I'm not a professional welder, these are just my experiances. BTW, the Millermatic 180 is a great choice. I have one Miller in 120v and one 230v. The 120v machine is OK for light stuff where 230v may not be available, but thats about it.
/ Quick MiG question #3
If you use flux-cored wire, you do not use shielding gas. The use of gas and solid core wire will give better looking welds, and you won't have to remove slag from the weld area.
The weld strength should be the same for both...
What do you mean by "Main use of welder would be indoor"? You need plenty a good ventilation while welding!
/ Quick MiG question #4
amp for amp you'll get a little more weld penetration with fluxcore wire but it'll spit little balls of steel out in every direction that meld real strong and are a pain to clean up.
IMO, if you're thinking of using fluxwire only just to avoid having to get tank(s) and gas you might as well just buy and use a stick welder. Stick welding can give stronger welds, it can be done without much regard to the weather (they do it underwater with specialized equipment), and the startup DC machine is cheaper, usually. Get a supply of 6013 rod ("the farmer's rod") and it'll start easily and make very nice results with a little practice. Also you can weld thicker stuff most of the time on the typical home power available (220v - 50a breaker). The Lincoln DC "Tombstone", the all time classic can weld most anything tractor and costs less than $250. new. Remember now, I SAID that all this is my opinion only.
Mig welding, shielded welding with assorted gasses, is easiest to learn and will give nice looking welds by simply following directions and welding charts. No mess, seldom any cleanup grinding, and you'll be proud of yourself.
The Miller 180 is a good one, it makes nice smooth arcs - expert weldors are raving about it. :). Again IMO, you'd be wasting it's good quality using fluxcore wire through that welder. It's making my Miller 210 wonder about it's little brother's intentions, keeps it awake nights.
Greetings;
To set minds at ease, by "indoors" I mean garage with door open and exhaust fan.
Hill: You're entirely correct about the gas. My only thought here was to save the $'s and the hassle for the gas. Having said that I don't really want to spend a whole bunch of time cleaning up splatter either.
I recently had one of my customers do a bit of welding for me (they're a store fixture company) and the shop foreman's general advice seemed to be that MiG has the shortest learning curve and produces one of the cleanest, strongest welds for medium price range. I've been flipping the coin for weeks on stick vs MiG. I would describe myself as being relatively handy, I have a small engine lathe and milling machine but haven't done any welding as yet and am running out of welding favours to ask.
Cheers,Erik
/ Quick MiG question #6
Hill, try anti-spatter spray before you weld on your metal, the little balls will come right off. Even PAM vegetable spray works better than nothing.
Erik, if you can afford a 220 MIG setup they work well, this isn't to say that the 110 rigs don't work, its just that the 220 setups are way more versatile. Good luck with your choice.
/ Quick MiG question #7
The MM 180 is a 220V rig.
Gas is cheap and last a long time if you get a good size bottle and is easy to work with.
I have a MM175 and have only used solid wire and gas. I am going on two years on my last fill and have done many home projects. I will have to refill soon since I am down to 300psi, it will cost me @35.00 to get a refill.
/ Quick MiG question #8
Hi Eric,
Heres my thoughts, you say that you have a lathe and mill so I would defiantly go with the 180 with gas. Build ups are easy and with out slag pockets. I have a small Lincoln 125 and an old 220 AIRCO stick machine for the heavy stuff. The 180 is a good mid machine but I would also invest in a "buzz box" from a yard sale very handy when you need to do rusty, dirty and painted steel.
remember it's all good
Phil
/ Quick MiG question #9
I have a Lincoln 125 which is gas capable, but I have only used it with flux core. It has given excellent service up thru 1/4" for nearly 10 years now, but the larger duty cycle of a 240V machine would be desireable.
I use a die grinder and wire wheels(gloves and face shield a must) to clean up the light slag and small spatter left from the flux core wire. Places I can't get with the wheel, I use a toothbrush sized wire brush. For the larger splatter out on open areas, I use a large file layed flat and slid across the surface sideways(like draw filing). This pops the spatter balls right off the base metal with little effort.
/ Quick MiG question #10
MY WELDING EXPERIANCE, CERTIFIED IN STICK AND WIRE. UNION PILE BUCK.
WELDED 3 FT. X 1 1/2" FLANGE FOR YEARS. ALL U. T. INSPECTED. MOST OF IT FLUX CORE NO GAS. OWN A MM210 1 OF 3 MACHINES I OWN. LOVE IT. ALL THE HI RISERS IN S.F. ARE FLUX CORE NO GAS. THIS ANSWER YOUR QUESTION?
/ Quick MiG question #11
Check out the Hobart 187 and the new Hobart 200 models before you buy a mm 180. Use the saving to lease a tank so you can use gas and solid wire. You won't have all the splatter and smoke you have with flux core.
There's a hobart welder's forum and there's also a miller welding forum you should check out.
/ Quick MiG question #12
Miller and Hobart are owned by ITW (Illinois Tool Works). I'm not saying the machines are the same inside, with different trim outside the way car manufacturers do with their brands (e.g. Chevy Suburban, Cadillac Escalade = same base chassis).
I have a MM210 and I am happy with it. Get the 240 VAC machine of your choice and if you are in a garage or other non-windy area; the gas is no hassle at all to use. Wiring up a 240VAC circuit is no big deal if you have room in your panel or sub-panel for the breaker. I want a spool gun for my MM210 so I can try some aluminum welding. I'd like a TIG unit too. I never could get the knack of stick welding in junior high metal shop. I'd either get the rod stuck, or burn through stuff. Auto darkening helmets weren't invented yet, so doing the visor flip added to my frustration.
Check out svcguy's stick welding at http://www.tractorbynet.com/forums/build-yourself/104835-homemade-rops.html
/ Quick MiG question #13
Yes Miller and Hobart are owned by the same company. There are differences though. Miller uses cast parts on the roller feeds and Hobart uses composites.
I looked high and low for a year at welders and asked a lot of questions. The answer Miller is more geared toward the professionals and Hobart toward the hobbist or home-owner. I plan on having this MIG a long time and do a lot of projects with so that is the direction I went. The other thing to consider is duty cycle. The MM180 is around 30%, but when you go up a unit the duty cycle jumps a lot.
I have a MM210 and I like it a lot
Dan
/ Quick MiG question #14
You should try DC stick with 7018 rod. A little hard at first, but once you get it down it is awesome!!
Dan
/ Quick MiG question #15
Eric, I also had the same dilemma, I wanted MIG but no gas bottle hassle. I spent a bit more money up front and got the Miller Passport. It's 110 OR 220 and the gas used is refillable small paint ball co bottles that I get filled at Academy sports and outdoors store. The bottles last longer than I thought and I use about 2 bottles per small roll of wire. Its very portable and I have use it off a 5500 watt generator also. Just another thought.....
/ Quick MiG question #16
Dan
I'll put a stick welder on the wish list! :)
When I was shopping for my MIG welder, which is my first one; I asked a couple of friends who are knowledgeable on welders and welding and they said go with Miller or Lincoln. I'm glad I took their advice.
/ Quick MiG question #17
I did a lot of reading before I bought my Hobart 180 I have been very happy with it and the 187 is supposed to be the felines nightie. I started with flux core wire and later bought a 80 Cubic foot bottle of 75/25. I can tell you the gas amounts to MUCH less hassle than the flux core and a small tank like mine lasts a lot longer than I thought it would. A trip to the welding store once in a while verses cleaning every weld you make just like stick welding.
We only had a stick welder on the farm growing up and later when I decided to help build a race car all we could afford was a stick welder. I found it pretty hard to Learn mig welding. Well, at least when I was expecting it to be very easy compared to stick according to everything I had read. There are a lot of variables in a mig welder wire speed, voltage , travel speed, gun angle, stick out, gas flow, but once you get it down its about like a hot glue gun.
Whatever you decide you can ask questions about any brand on hobarts forums Weld Talk Message Boards - Powered by vBulletin They are a nice bunch of people over there, kinda like here.
/ Quick MiG question #18
I'd encourage anyone trying to select a welding machine to go to the Weld Talk website Berniep posted. There is a huge amount of useful information about flux core versus gas wire welding and selecting the appropriate welding machine for your needs and budget.
I'd say just about everyone would like to have a new MM212, but when you add on an autodarkening helmet, a tank, some good grinders, a good bandsaw, etc. you can get quite a bit of money invested. This too, has been well discussed on Weld Talk.
Once you figure out which welder you want and can afford, then this is the best site I've found to see what you can weld to use with your tractor.
/ Quick MiG question #19
likewise, love my passport. I can fill my own CO2 bottles but use external mixed gas tank when it is in my garage.
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
Hercules Gun Safe Holds 20 Guns (A65583)
Hercules Gun Safe...
2018 Ford F-150 Crew Cab Pickup Truck (A64556)
2018 Ford F-150...
HONDA Plate Compactor (A64557)
HONDA Plate...
