Pat's Easy Change Quick hitch or Pats??????
/ Quick hitch or Pats?????? #1
wr400
wisconsin
2000 Jd 990
Which is prefered the quick hitch or some of the slip on things like the pats or ones seen on ebay.
Thinking of getting one or the other an have little idea on how they work
Jeff
/ Quick hitch or Pats?????? #2
I'd stay away from the Harbor Freight stuff and don't trust the eBay stuff either. I don't use Pat's myself but many people like it and he stands behind his product.
/ Quick hitch or Pats?????? #3
I have just too many attachments that have the lift pins spaced differently or the attachment is not quick hitch compatable. I went with Pat's system. I think there are others here that would say they like their quick hitch. I think if you have a quick hitch before you start buying attachments, then make sure that they are quick hitch compatable, or can easily be altered, you will be OK. I myself like to buy used when I can, and the attachment doesn't always meet the standard of a quick hitch.
Oh, I see you are a welder by trade. So altering attachments to fit probably won't be an issue for you. Just something to keep in mind before buying I guess.
I can modify about anything. But really not sure about thease two items. So with the quick hitch I need to have adapters an with the pats I just back up raise the three point an hook up the top link? I would like to here a few more opions on the two.
Jeff
/ Quick hitch or Pats?????? #5
Jeff
There are special washers that need to be pined on to the lift pins for Pat's system. They are included with the purchase. But more can easily be made. If I think off it, I will run out and get a picture of them. They are nothing more than a bent washer with an additional hole drilled in them.
One other thing I forgot is that you need something to hold the lower lift arms apart when backing up to your attachemnt. Pat sells a telescoping rod assembly, but I know others have just made their own.
Addendum: Here are the pictures I promised.
BTW, I have no affiliation with Pat. Just a satisfied customer.
/ Quick hitch or Pats?????? #7
Arn't impliments built to a standard based on their Cat rating?
Therein lies the rub. There's a standard, but there's no enforcement. That's why I gave up and sold my QH, then replaced it with PEC system. Worked so good on my 45 horse (Cat 2), that I bought another set for my 35 horse (Cat 1).
//greg//
/ Quick hitch or Pats?????? #8
A lot of the newer things have taken that into consideration, but not all. Then you get into the CUT and SCUT, limited cat1, regular cat1 hitch. So the buyer needs to beware of this stuff when purchasing an attachment.
/ Quick hitch or Pats?????? #9
The quick-hitch relys on a hook at the top link attachment point. On some this hook is a fixed position and some provide a little adjustment, but the equipment must have a top link pin that is correctly positioned and accessible for that hook to engage it. Many older and some new equipment is NOT compatible and I have never seen a post hole digger that was compatible.
I first boiught a quick hitch but found that I had to remove it frequently.
I then bought one of those sets that is similar to Pat's but use a pin and quick clip to retain the attachment. Those did not fit my lower links very well and were very difficult to align with the attachment when hooking up. They also were showing significant wear after a few months of use.
I then bought a set of Pat's and am pleased with them. They are not perfect but they work best for me (of any of the things I have tried).
Thanks guys. I might have to look at the pats. Anyone know which would be better for the tractor?
/ Quick hitch or Pats?????? #11
Who knows for sure? My guess is the frame of a quick hitch can help alot to distribute the loads to both lower and top link connection points.
I have and like the I Match setup and have adapted most of my implements to it. I am very well pleased with it, it makes attaching to a regular 3 pt implement a minute or two without leaving the cab.
/ Quick hitch or Pats?????? #12
I use a Quick hitch and I had to modify most of my no name equipment to fit. Why did I have to do all of this because Pats would not fit so I went the route of Quick hitch and I love it. The Pats system was my first choice for all of the reason that you all have stated but I went to pick it up and I find that you need the first 4 inches of the lift arms to be straight. The Kubota L4400 is straight about 3 (I could be wrong about the dimensions but it wouldn't work).
/ Quick hitch or Pats?????? #13
Pat's works fine for me. Match that with a hydraulic top link and you are set. Fabricate some PVC extensions so you can lift 30h and/or extend top link while standing at rear of tractor and hooking up the implement and you are as near to heaven as you can get while getting your hands dirty.
Pats system comes in cat 1 and cat II ..... when I got mine, only could get cat II thru Pat himself..
Pat stands behind his product... I recommend it.
Jack Daniels Metal Decorative Sign (A66738)
Jack Daniels Metal...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2015 Caterpillar 906H2 (A64911)
2015 Caterpillar...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
