Quick Hitch 3/4 pins?
   / Quick Hitch 3/4 pins? #1
S854
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
Just picked up a HF quick hitch...
Is there a reason the stock lower pins are smaller diameter than the cat 1 pins?
I have an older Massey and needed to connect sway bars to the pins (in addition to the lift arms) ...ended up hogging out the lower mounting holes on the new QH so I could put in longer, 7/8 pins to accommodate the sway bars.
   / Quick Hitch 3/4 pins? #2
What QH did you buy?
Harbor Freight... (a frugal buzzard...)
   / Quick Hitch 3/4 pins? #7
Humm, wonder if they had a run were they punched the top link holes and the draft arm holes the same. I know they had the width issue for a while but later was ok, I have 2 from there about 10 years old with no issues, but haven’t looked at the new ones lately.
   / Quick Hitch 3/4 pins? #9
About the pin sizes... And categories....
Either replace pins or use sleeves to match QH...
If you need to make holes larger for pins, look at "bridge reamers" (tapered), expensive but makes job really easy....
13H830_AS01
Dale
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A51039)
2016 Ottawa Yard...
2015 Chevrolet Cruze 1LT Sedan (A48082)
2015 Chevrolet...
SDLG WHEEL LOADER FORKS MAST W/ 48" FORKS (A51242)
SDLG WHEEL LOADER...
2012 Dodge Journey SE SUV (A48082)
2012 Dodge Journey...
2022 Club Car...
