Quick Hitch 3/4 pins?
/ Quick Hitch 3/4 pins? #1
S854
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
Just picked up a HF quick hitch...
Is there a reason the stock lower pins are smaller diameter than the cat 1 pins?
I have an older Massey and needed to connect sway bars to the pins (in addition to the lift arms) ...ended up hogging out the lower mounting holes on the new QH so I could put in longer, 7/8 pins to accommodate the sway bars.
Harbor Freight... (a frugal buzzard...)
/ Quick Hitch 3/4 pins? #7
Humm, wonder if they had a run were they punched the top link holes and the draft arm holes the same. I know they had the width issue for a while but later was ok, I have 2 from there about 10 years old with no issues, but haven’t looked at the new ones lately.
/ Quick Hitch 3/4 pins? #9
About the pin sizes... And categories....
Either replace pins or use sleeves to match QH...
If you need to make holes larger for pins, look at "bridge reamers" (tapered), expensive but makes job really easy....
13H830_AS01
Dale
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
2016 Ford F-150...
