Quick Hitch 3/4 pins?
/ Quick Hitch 3/4 pins? #1
S854
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
Just picked up a HF quick hitch...
Is there a reason the stock lower pins are smaller diameter than the cat 1 pins?
I have an older Massey and needed to connect sway bars to the pins (in addition to the lift arms) ...ended up hogging out the lower mounting holes on the new QH so I could put in longer, 7/8 pins to accommodate the sway bars.
Harbor Freight... (a frugal buzzard...)
/ Quick Hitch 3/4 pins? #7
Humm, wonder if they had a run were they punched the top link holes and the draft arm holes the same. I know they had the width issue for a while but later was ok, I have 2 from there about 10 years old with no issues, but haven’t looked at the new ones lately.
/ Quick Hitch 3/4 pins? #9
About the pin sizes... And categories....
Either replace pins or use sleeves to match QH...
If you need to make holes larger for pins, look at "bridge reamers" (tapered), expensive but makes job really easy....
13H830_AS01
Dale
2008 CHEVROLET 2500HD TRUCK (A63290)
2008 CHEVROLET...
Bigfoot Sign (A62183)
2015 Chevrolet 3500HD (A62180)
2015 Chevrolet...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
LandHonor Mini 44" Bucket Grapple (A62183)
LandHonor Mini 44"...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
