Loader Quick connect problem, not due to pressure ,
/ Quick connect problem, not due to pressure , #1
Rusty4242
Western Mass.
Kubota BX23
Took my snow thrower of my BX23 for the season and tried to mount the FEL again. The retractable collar on one of the 4 qc fittings won't snap foward in place when the 2 fittings are mated fully. All The bearings are free and clean. What's the problem? thanks, Larry
/ Quick connect problem, not due to pressure , #2
Not quite fully mated? Try twisting a little.
/ Quick connect problem, not due to pressure , #3
Are you sure it is fully mated? A little internal pressure could keep it from being in place. Did you relieve the pressure?
I had a very rare problem a few months back where the little internal spring broke and the collar would not snap back into position by itself. I ended up putting on a new connector end.
/ Quick connect problem, not due to pressure , #4
I had a similar problem with the chute rotator hoses for my rear snow blower a couple of years ago. There was no way I could get the connectors to lock despite the connectors being at an ideal height and position and pressure completely released on the hoses. I finally used a heat gun to warm the female connector on the tractor and the collar easily fell into place. I have not had the same problem since but that may be because I seldom remove the connectors over the winter. Perhaps it was a unique condition caused by a certain (cool) temperature while trying to reconnect and the heating fixed that. I was surprised when heating fixed it.
2005 John Deere 7320 (A60462)
2005 John Deere...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
1999 New Holland 688 Round Baler (A63688)
1999 New Holland...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2013 CORPUS 40FT  T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
