Loader Quick connect problem, not due to pressure ,
/ Quick connect problem, not due to pressure , #1
Rusty4242
Western Mass.
Kubota BX23
Took my snow thrower of my BX23 for the season and tried to mount the FEL again. The retractable collar on one of the 4 qc fittings won't snap foward in place when the 2 fittings are mated fully. All The bearings are free and clean. What's the problem? thanks, Larry
/ Quick connect problem, not due to pressure , #2
Not quite fully mated? Try twisting a little.
/ Quick connect problem, not due to pressure , #3
Are you sure it is fully mated? A little internal pressure could keep it from being in place. Did you relieve the pressure?
I had a very rare problem a few months back where the little internal spring broke and the collar would not snap back into position by itself. I ended up putting on a new connector end.
/ Quick connect problem, not due to pressure , #4
I had a similar problem with the chute rotator hoses for my rear snow blower a couple of years ago. There was no way I could get the connectors to lock despite the connectors being at an ideal height and position and pressure completely released on the hoses. I finally used a heat gun to warm the female connector on the tractor and the collar easily fell into place. I have not had the same problem since but that may be because I seldom remove the connectors over the winter. Perhaps it was a unique condition caused by a certain (cool) temperature while trying to reconnect and the heating fixed that. I was surprised when heating fixed it.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2019 VOLVO L90H WHEEL LOADER (A65053)
2019 VOLVO L90H...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
2004 International 7400 C&C 017797 (A62613)
2004 International...
