Loader Quick connect problem, not due to pressure ,
   / Quick connect problem, not due to pressure , #1
Rusty4242
Bronze Member
Western Mass.
Kubota BX23
Took my snow thrower of my BX23 for the season and tried to mount the FEL again. The retractable collar on one of the 4 qc fittings won't snap foward in place when the 2 fittings are mated fully. All The bearings are free and clean. What's the problem? thanks, Larry
   / Quick connect problem, not due to pressure , #2
Not quite fully mated? Try twisting a little.
   / Quick connect problem, not due to pressure , #3
Are you sure it is fully mated? A little internal pressure could keep it from being in place. Did you relieve the pressure?
I had a very rare problem a few months back where the little internal spring broke and the collar would not snap back into position by itself. I ended up putting on a new connector end.
   / Quick connect problem, not due to pressure , #4
I had a similar problem with the chute rotator hoses for my rear snow blower a couple of years ago. There was no way I could get the connectors to lock despite the connectors being at an ideal height and position and pressure completely released on the hoses. I finally used a heat gun to warm the female connector on the tractor and the collar easily fell into place. I have not had the same problem since but that may be because I seldom remove the connectors over the winter. Perhaps it was a unique condition caused by a certain (cool) temperature while trying to reconnect and the heating fixed that. I was surprised when heating fixed it.
10' Poly Feed Trough (A50515)
10' Poly Feed...
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
LG 60" PIN ON WHEEL LOADER FORKS (A51242)
LG 60" PIN ON...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2018 FABRIQUE 20FT TRAILER (A52141)
2018 FABRIQUE 20FT...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
