"Quick Bite"
/ "Quick Bite" #22
the more pivets and points added the more possiblity of breakage just my :2cents:
/ "Quick Bite" #23
The Quick Bite is very similar in operation to an autolock coupler found on gooseneck trailers:
28" - 38" Gooseneck Trailer Coupler - 24K - 4" Square Auto Lock Trailer Coupler LL2516ST
Gooseneck Coupler - 24K Auto Lock Trailer Coupler SM2516NP
I have had a similar style of coupler installed on two gooseneck trailers I've owned. Works exceptionally well. You simply gently back up into it until it closes. If I had a bumperpull trailer I think an autolock coupler like the Quick Bite would also be ideal.
/ "Quick Bite" #24
It looks pretty cool. I pull my big trailer 4to5 times a month. Each time I unhook it I put a brick behind the left side rear Truck tire. When I back up the next time, I usually get it right on the first try. If I am off a little I can shift the coupler just enough to slide on the ball. If the Trailer is Loaded when I hook up the shifting won't work. That may take two tries.
I think this hitch will sell. I see new trailer pullers buying it more so than guys that has been pulling trailers for years. Some people make hooking up seem harder than it really is.
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59912)
2009 STRICK 53X102...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
