"Quick Bite"
/ "Quick Bite" #22
the more pivets and points added the more possiblity of breakage just my :2cents:
/ "Quick Bite" #23
The Quick Bite is very similar in operation to an autolock coupler found on gooseneck trailers:
28" - 38" Gooseneck Trailer Coupler - 24K - 4" Square Auto Lock Trailer Coupler LL2516ST
Gooseneck Coupler - 24K Auto Lock Trailer Coupler SM2516NP
I have had a similar style of coupler installed on two gooseneck trailers I've owned. Works exceptionally well. You simply gently back up into it until it closes. If I had a bumperpull trailer I think an autolock coupler like the Quick Bite would also be ideal.
/ "Quick Bite" #24
It looks pretty cool. I pull my big trailer 4to5 times a month. Each time I unhook it I put a brick behind the left side rear Truck tire. When I back up the next time, I usually get it right on the first try. If I am off a little I can shift the coupler just enough to slide on the ball. If the Trailer is Loaded when I hook up the shifting won't work. That may take two tries.
I think this hitch will sell. I see new trailer pullers buying it more so than guys that has been pulling trailers for years. Some people make hooking up seem harder than it really is.
3PT FENCE ROW SPRAYER (A63291)
3PT FENCE ROW...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
11in. Tooth Excavator Bucket (A64194)
11in. Tooth...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
3PT WEIGHT DRUM W/ CONCRETE FILLER (A63291)
3PT WEIGHT DRUM W/...
