Backhoe Quick Backhoe Oper. Question
   / Quick Backhoe Oper. Question #11
With out the bucket on it will be a little light in the front. If its close (10mile or less)I would drive it.
   / Quick Backhoe Oper. Question #12
Put the loader bucket in the back of the pick up. Then hook up the trailer and load the tractor.
MarkV
   / Quick Backhoe Oper. Question #13
16'? THAT SHOULD BE ENOUGH. tHE HOE CAN HAng out the back a little and you can also raise the loader above the tailgate of the truck. The most important thing is that the center of the laod is above the tires. I get my L48s on 16 and 18's no problem and I use my mentioned technique when I have the hoe off and a 6' bush hog on the back. Although the BH75 is smaller than what I use....be aware of boom swing when trailering. I have had that happen and that is why there is a boom swing pin/lock to prevent this. Having the hoe to the side may not be a weight cenetring problem but be careful about the swing, especially if it can hit a tie down chain. Ramp trucks up here are $70 plis 2$ amile so maybe your friend will pay for that if need be as hiring someone would certainly cost more than that to do the job. Oh, and yes, bring the loader, digging anything 4' deep creates massive amounts of backfill which your loader will make quick work out of compared to resetting all the time and using the hoe to backfill. Good luck.
   / Quick Backhoe Oper. Question #14
Rent a trencher. It'll do a much nicer job on a waterline than your backhoe ever will, and it will fit in the stock trailer!
   / Quick Backhoe Oper. Question #15
I agree with renting a ditch witch.
The rental cost coule be quiet reasonable and much easier and faster results.
When I put in a new water line, a friend of mine borrowed a ditch witch on a bob cat. What a sweet little machine, it crawled up steep hills like its no big deal. Had the job done in a couple of hours. Had I used my tractor, I probably could not finish some of the hill sides.
Good luck.
   / Quick Backhoe Oper. Question #16
I agree with renting a trancher. It's faster easier and will give you a smoother bottom. While I'm not saying that you are unable to get a smooth bottom with you backhoe, it does take some skill and practice to be proficient at it. I have a fair number of hours on a backhoe and I still waste allot of time getting the bottoms of my trenches smooth and flat. I now have a trencher and would never use my backhoe over it for water lines.
I did 1,200 feet one time with a walk behind trencher in one day. It was a real pain, but easily doable. 60 feet is nothing.
Eddie
   / Quick Backhoe Oper. Question #17
Ditch witch??? Water lines up here are 4-5' deep and I cannot see how you can possibly work in a trench that skinny and deep. Besides, 1 decent rock and you are out of luck. Granted I live in NH where you need a hoe just to plant bulbs cause of the rocks. Don't forget....trenching and working in a trench for those who don't do it often is VERY dangerous. My neighbor DIED when the trench collapsed on his waterline project. Keep the trench sloped and the walls free from visible collapse.
   / Quick Backhoe Oper. Question #19
He didn't say how deep he has to go, so if it's 6 feet, then renting a trencher that large is going to be too expensive. 4 feet is pretty standard at a rental yard.
For the life of me, why would anybody want to get into the trench when installing water lines? For larger pipe, gasket pipe is best, but for just 60 feet, it really wont matter. If it's one inch or smaller, just glue them up beside the tench and lay the pipe in the trench. There's no reason to make this any harder then it needs to be, and water lines are about the simplist thing out there to do.
If glueing, use purple primer and clear, heavy duty glue. The primer is very important. It's softens the pipe and allows the glue to actualy weld the pipe or fittings together.
Eddie
   / Quick Backhoe Oper. Question #20
Not to hi-jack your thread, but how do you like the back-hoe on the L2800? One of the first major things I buy for my L3400 will probably be a back-hoe in a year or two (or three).
Good luck on the trench. If it's within a few miles I think I would just drive.
I've got a L2800 with BH75 hoe. My cousin needs about 60-70' of waterline laid at his new house. He has a 16' stock trailer and my TLB will not fit. However, if I remove the loader it will fit. Would you all see any problems in digging this little bit of a trench without the FEL on the tractor. I thought I would be OK if I just go slow and easy. Terrain is flat. Thanks guys.
NEW Fork Extensions (A59000)
NEW Fork...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
2015 Hoist P360 36,000lb Diesel Forklift (A55973)
2015 Hoist P360...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
