Quick attach set-up for KL1450
/ Quick attach set-up for KL1450 #1
mefyj
Sunny Arizona
Kioti DK35
Considering a quick attach system for my KL1450 FEL on my DK35. My buddy has a bob-cat with lot's of attachments that I could occasionally put to good use. :)
However I'm not certain which aftermarket unit may be best for me. I have seen the homemade versions on this site but that may be beyond my expertise & existing shop equipment. Don't want to loose anymore lifting capacity than necessary. However I have upgraded my cylinders to handle more curl than the OEM's.
I can easily do the conversions to my implements but not to the loader.
Any feedback would be appreciated.:thumbsup:
/ Quick attach set-up for KL1450 #2
I may have one left over in my old inventory.
Would you be interested in it at $500 if I can find it?
/ Quick attach set-up for KL1450 #3
mefyj,
Where did you get the cylinders to upgrade/increase your curl function.
I am interested in the same function.
Wallace,
Let me know if you can find it... I suspect that includes shipping to AZ!:thumbsup:
Skinnyman....
I just found a larger bore that had the same length stroke as the original's. They work a little slower but have more strength. Had to weld new ends but it was a simple exchange once you have access to the cylinders.
/ Quick attach set-up for KL1450 #6
Wallace,
Sorry I don't have the style you need I have a different one.:(
/ Quick attach set-up for KL1450 #8
I am looking for one for a 1470 loader. Any luck, or is it the same as the 1450? PM me if u can hook me up.
Lot's of searching has brought me to the point of building my own Quick Attach for the KL1450. :( Will be less expensive than any aftermarket items I have found. Have a friend that will assist with some of the work and it will be a learning project for me.
This may be a good time to further assist my curl capacity. Seems like I remember reading where someone had adjusted the spacing on the bucket holes. However not certain if that will do much and may cause the loss of some motion.
Any further feedback will be appreciated.
/ Quick attach set-up for KL1450 #11
I might be able to save you a bunch of hassel...
I can sell you this one. All you will have to do is put your holes where you want.
$475 to your door!
/ Quick attach set-up for KL1450 #12
tulenutn2o
Same deal for you if ya want one also!
Thanks for this option. However the photo's show the plate to be a great distance from the loader pins. Many quick attach setups are much closer, as my design will be. So I think I'll pass.
Deere 333E (A60462)
Deere 333E (A60462)
5.5x13 Homemade Trailer (A62613)
5.5x13 Homemade...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2022 EZ-GO ELITE...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
iDrive TDS-2010H...
