Questions: new to me YM2010
   / Questions: new to me YM2010 #1
ufengineer
Bronze Member
Jacksonville, florida
ym2010
I noticed that the drivers side wheel bearing has some Play in it. If I grab the top of the wheel and push/pull there is a bit of play in the hub. Should I leave it or look to replace the bearing.
Also, the oil is very black and the transmission fluid looked new. I think the owner replaced the transmission fluid before advertising it because it was sludge like. I looked in the dip stick hole and saw remit sludge like oil. What should I do? Run it for a while then change the oil again.
Thank mike
   / Questions: new to me YM2010 #2
There is a 6205 and a 6206 ball bearing in there. If everything is right there should be no play. If much I would repair before other damage is done. Yanmar Tractor Parts: 2WD AXLE
Would it be possible to ask the former owner if he cleaned the suction strainer when changing the transmission/hydraulic fluid?
2121 (A51244)
2121 (A51244)
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
