Questions before I buy.
   / Questions before I buy. #21
I tried a frost plug heater once. Didn't like the way it worked. Darn thing leaked and I could not stop the leak. I've always used a lower radiator hose heater since that time. Work fine for me.
   / Questions before I buy. #22
People: pop a frost plug out, install a sleeve using form in place gasket sealer, and screw in a block heater with teflon tap to seal it.
486658d1478064209-ck35-block-heater-460363d1457640886-nx-cab-radiator-heater
486659d1478064260-ck35-block-heater-460364d1457640935-nx-cab-radiator-heater
The only caution is when removing the frost plug do not drill or punch into the cylinder wall.
Thanks for the info all in one place Eric, makes it easy.
   / Questions before I buy. #23
I installed a frost plug heater in mine. I even made my own sleeve, and I think it took me under an hour. That includes the time it took me to drain and refill the coolant.
Super easy. No leaks. Works great.
Make sure the hole is good and clean before you install the sleeve. Use permatex high temp sleeve retainer.
This will warm the block and the coolant and makes for a nice easy start at -20. Some people complain about the lower rad hose heaters losing too much heat out the rad, but I have no personal experience with them.
Utility Cart (A55851)
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2003 Ford F-350 4x4 Altec Service Truck (A55852)
2003 Ford F-350...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
PULL BEHIND PADFOOT COMPACTOR (A52707)
PULL BEHIND...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
