Questions before I buy.
   / Questions before I buy. #21
I tried a frost plug heater once. Didn't like the way it worked. Darn thing leaked and I could not stop the leak. I've always used a lower radiator hose heater since that time. Work fine for me.
   / Questions before I buy. #22
People: pop a frost plug out, install a sleeve using form in place gasket sealer, and screw in a block heater with teflon tap to seal it.
486658d1478064209-ck35-block-heater-460363d1457640886-nx-cab-radiator-heater
486659d1478064260-ck35-block-heater-460364d1457640935-nx-cab-radiator-heater
The only caution is when removing the frost plug do not drill or punch into the cylinder wall.
Thanks for the info all in one place Eric, makes it easy.
   / Questions before I buy. #23
I installed a frost plug heater in mine. I even made my own sleeve, and I think it took me under an hour. That includes the time it took me to drain and refill the coolant.
Super easy. No leaks. Works great.
Make sure the hole is good and clean before you install the sleeve. Use permatex high temp sleeve retainer.
This will warm the block and the coolant and makes for a nice easy start at -20. Some people complain about the lower rad hose heaters losing too much heat out the rad, but I have no personal experience with them.
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2015 Autocar Xpeditor T/A E-Z Pack 40 Yard Front Loader Garbage Truck (A55852)
2015 Autocar...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
UNUSED WOLVERINE DUM-26-73W 73" HYD DRUM MULCHER (A57193)
UNUSED WOLVERINE...
UNUSED FUTURE PG72 72" HYD PLATE GRABBER (A57193)
UNUSED FUTURE PG72...
