You really have 2 common options:
1: Third function kit (typically utilizes your tractors "power beyond" line. Bit of a buzzword the industry likes to use making this seem amazing. Just means this function gets its pressure from after the distribution block that services the loader)
2: Using rear remotes (often installed standard on tractors these days)
Third Function Kit
Pros:
*Button right on loader joystick to actuate attachment
*Kit has everything in it you need. Don't have to find parts and piece together
*Great resale point
Cons:
*$900 for the kit. Installation is a bit more involved but certainly DIY.
*Valve is either open or closed, there is no feathering, so lots of quick clicks of the button.
*Not Proportional, you most likely will not be able to use this function and another loader function at the same time. Over at
Everything attachments, they advertised their 3rd function kit saying "This is a full 3rd function kit allowing you to raise/lower, dump/curl, and open/close at the same time." This is a false statement for many tractors, depending on pump flowrates. Most tractors under 60hp will simply not be able to do this. Good people, and helpful, but misleading in their advertising.
I know MIE is working on a proportional kit, above and beyond there normal 3rd function kit aimed at solving this, I'm sure it will be more expensive but I think it would be worth calling MIE and asking about it. Perhaps
Everything Attachments will do the same.
Rear Remote
Pros:
*Cheap, Less than $300 buying your hoses and fittings from Discount hydraulic or similar
*Uses existing equipment, so certainly simpler.
*Depending on the tractors 3rd function, it may be able to feather.
Cons:
*Have to use the tractors remote stick to actuate attachment, not as convenient as button right on FEL joystick
*If you don't have remotes already, these will need to be installed, bumping up the cost to what a 3rd function kit would be.
I have 2 DK45se Hst tractors, one with
Everything Attachments kit, and the other tractor utilizing the rear remotes. If anyone were looking for advice because they were a bit tight on money, I would recommend getting the rear remote set up first, Plan your hose order in such a way that if later on, should you save up more cash, you may be able to order a 3rd function kit without the lengthy hoses, reducing the kit cost.
If you are only using your
grapple a couple hours a week, the rear remote option is just fine, especially with some simple modifications, like lengthening the remote engagement stick to reach up near the FEL stick. If someone uses their
grapple a few hours every day, having that button on the joystick is a wonderful thing.
