Question Tailgate assist
/ Question Tailgate assist #1
Lucky1
Bronze Member
Does anyone know what pound springs (Useing 2 springs, 1 on each side) it would take to lift a 160 pound landscape tailgate. Need short spring about 16 - 18'' long. Don't want garage spring. Thank You
/ Question Tailgate assist #2
It's going to depend on where the spring is attached to the tailgate in relation to the hinge point. The further from the hinge, the lighter the spring needs to be. However it does need to be longer/have more travel. Use a scale and measure the down pressure of the gate at the furthest point from the hinge. You'd need a spring with a pull of approx have of that, assuming two springs. If the attach point is halfway to the hinge, the springs need to be twice as strong. It's all in the leverage.
/ Question Tailgate assist #3
I was trying to figure out how to do this a few years ago and it got real complex real quick. I bought the Gorilla Lift through Northern Tool. I got it on sale for about $139 if I remember and it's great. I could have spent weeks and still ended up with something that didn't work as well.
I am having a Amish welding shop do this as he rebuilt the tailgate and changed the front so I could open the tailgate on my pickup with the trailer hooked up. He did put the tailgate on a scale and came up with 80 pounds. He figured to go between 8 and 12 inches up the ramp, would two 100 pound springs sound about it, he said something about makeing them adjustable.
/ Question Tailgate assist #5
Go to junkyard and get torsion stabiliser for the spring. It is space efficient and not as dependent on perfect geometry. It doesn't need to lift the gate all the way up. Once it is lifted to certain angle it is easy to push it over to vertical position.
Does anyone know the pound pull of the spring on a Gator assist on their landscape trailer?
/ Question Tailgate assist #7
Go here All Trailer Parts, Hydrastar, Dexter Parts, Dexter Axles, Brakes, Electric, Hydraulic, Springs and look under ramp springs. They are 1.5 od and about 13.625 long. I used one on a 4x6 top gate
with 2x2 tubing and mesh steel. Lone Wolf trailer ramp assist 2.jpgLone Wolf Trailer ramp assist.jpgLone Wolf Trailer ramp assist 3.jpg
The L bracket is .375 x 3" x 11" cold roll (Cut and bend to suit your trailer.)
shackles are .250 x1" x 3
Eye bolt from Home Depot.
/ Question Tailgate assist #8
Reviving an old thread. I am planning a spring assist similar to Stever and came across this thread. If you see this Steve can you post a video in operation. Did you have any trial and error about placement? My brake light is on the last upright and I am concerned about clearance. Plan on ordering the spring soon. Also need to figure out a bracket.
/ Question Tailgate assist #9
/ Question Tailgate assist #10
I can do the garage door spring set up but the short spring similar to the Gatormade trailer makes more sense to me.
/ Question Tailgate assist #12
I built one simular to Stever00 a few years ago. I used threaded i bolts for fine tuning. The springs were similar to old (1950-1980) style truck hood springs. I'll try to get a picture in the morning. The trick was to raise/lower the gate gently.
/ Question Tailgate assist #13
From Subject Received Size
brewers 9:27 PM 1 MB
/ Question Tailgate assist #14
Garage door spring is too long and weak. Ok if you want spring running half way across your trailer like the yellow Gator springs. Ive made two of these. One for 12 foot Lone Wolf and last 16 foot Larimore trailer. Last one been on over 5 years. I can raise the gate off the ground with my foot, catch it with my hand and never have to bend over. Adjust your location point by using a chain held temporaily where you want it. Moving the chain hook on the spring and location point will tell you where you need to weld your spring older in order to take weight off gate and not break spring.
I just noticed i have some really nice shoes on in that photo. Lol
/ Question Tailgate assist #15
Why use a coil spring when a torsion spring is a much more compact option? I know it wouldn’t be a drop in no weld fit but I don’t imagine that’s what you want otherwise you’d buy a gorilla lift.IMG_6931.JPG
/ Question Tailgate assist #17
That spring cost me $18.50 cents. Gator lift what $160 to $200 ? I worked as machinist and enjoy making things. My neighbor had those Gator lift. Those cables rollers frazzled out in a few years. Lot of over engineered garbage for people with money to burn. Im not rich and rather buy groceries with my yard mowing money.
2012 Acura TL Sedan (A59231)
2012 Acura TL...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
Toyota SR1-BET35 3,500 LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
