Question Tailgate assist
/ Question Tailgate assist #1
Lucky1
Does anyone know what pound springs (Useing 2 springs, 1 on each side) it would take to lift a 160 pound landscape tailgate. Need short spring about 16 - 18'' long. Don't want garage spring. Thank You
/ Question Tailgate assist #2
It's going to depend on where the spring is attached to the tailgate in relation to the hinge point. The further from the hinge, the lighter the spring needs to be. However it does need to be longer/have more travel. Use a scale and measure the down pressure of the gate at the furthest point from the hinge. You'd need a spring with a pull of approx have of that, assuming two springs. If the attach point is halfway to the hinge, the springs need to be twice as strong. It's all in the leverage.
/ Question Tailgate assist #3
I was trying to figure out how to do this a few years ago and it got real complex real quick. I bought the Gorilla Lift through Northern Tool. I got it on sale for about $139 if I remember and it's great. I could have spent weeks and still ended up with something that didn't work as well.
I am having a Amish welding shop do this as he rebuilt the tailgate and changed the front so I could open the tailgate on my pickup with the trailer hooked up. He did put the tailgate on a scale and came up with 80 pounds. He figured to go between 8 and 12 inches up the ramp, would two 100 pound springs sound about it, he said something about makeing them adjustable.
/ Question Tailgate assist #5
Go to junkyard and get torsion stabiliser for the spring. It is space efficient and not as dependent on perfect geometry. It doesn't need to lift the gate all the way up. Once it is lifted to certain angle it is easy to push it over to vertical position.
Does anyone know the pound pull of the spring on a Gator assist on their landscape trailer?
/ Question Tailgate assist #7
Go here All Trailer Parts, Hydrastar, Dexter Parts, Dexter Axles, Brakes, Electric, Hydraulic, Springs and look under ramp springs. They are 1.5 od and about 13.625 long. I used one on a 4x6 top gate
with 2x2 tubing and mesh steel. Lone Wolf trailer ramp assist 2.jpgLone Wolf Trailer ramp assist.jpgLone Wolf Trailer ramp assist 3.jpg
The L bracket is .375 x 3" x 11" cold roll (Cut and bend to suit your trailer.)
shackles are .250 x1" x 3
Eye bolt from Home Depot.
/ Question Tailgate assist #8
Reviving an old thread. I am planning a spring assist similar to Stever and came across this thread. If you see this Steve can you post a video in operation. Did you have any trial and error about placement? My brake light is on the last upright and I am concerned about clearance. Plan on ordering the spring soon. Also need to figure out a bracket.
/ Question Tailgate assist #9
/ Question Tailgate assist #10
I can do the garage door spring set up but the short spring similar to the Gatormade trailer makes more sense to me.
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
2012 International 4300 Reefer Truck (A61307)
2012 International...
Deere 335P (A53317)
Deere 335P (A53317)
Husqvarna Riding mower (A56857)
Husqvarna Riding...
