question on john deere
/ question on john deere #1
mahon201
champlin mn
john deere 757 z trak
does anyone know why a john deere 757 z trak wants to die as soon as you start pulling the motion control handles in out of the lock positon and yes the e brake is off and it worked fine before i took the motor out to put new seals in it the motor runs perfect the pto works but now you have to be on the seat to even start it or let it idle and it wants to dies as soon as you touch the control handles
/ question on john deere #2
Sounds like a bad safety switch to me. Possibly on the brake since the pto will run. You'd just have to trace the linkages until you find a switch. Make sure it's secured to whatever moves to activate it. Then make sure it's plugged in. You could unplug it and check it with a jumper wire in the plug and see if it will move then, if it does then it's the switch.
/ question on john deere #4
Make sure the battery cables are on the right posts. Happened to a friend of mine and that's a symptom.
A JD757 Z-trac will start with the battery hooked up backwards?
2013 FORD F-150 (A67714)
2013 FORD F-150...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
PORTA POTTY (A67714)
