Question on iMatch
/ Question on iMatch #1
Gizmo2
New York
JD 2320
I am making a rear three point hitch ballast. I have a steel plate that measures 30 inches across and will need to mount the lower 3PH pins in from the edges of the steel plate so that I will stay I-Match compatible. Can someone give me the distance I need to allow for the I-Match lower hooks to clear the plate? How far away do I need to mount the pins from the steel plate? I plan on using two pieces of 5/16 angle iron 4 inches long that will be welded to the plate for the pin mounts.
jdbower,
It does not show the measurement I need.
/ Question on iMatch #4
Is this what you are looking for? It's about 1 1/8"
That's it, Thanks
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
100 Gal Oil Container (A64127)
100 Gal Oil...
2018 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 6X4...
2017 International HX620 Quint Dump (A62613)
2017 International...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
1062 (A63291)
1062 (A63291)
