Question on iMatch
/ Question on iMatch #1
Gizmo2
New York
JD 2320
I am making a rear three point hitch ballast. I have a steel plate that measures 30 inches across and will need to mount the lower 3PH pins in from the edges of the steel plate so that I will stay I-Match compatible. Can someone give me the distance I need to allow for the I-Match lower hooks to clear the plate? How far away do I need to mount the pins from the steel plate? I plan on using two pieces of 5/16 angle iron 4 inches long that will be welded to the plate for the pin mounts.
jdbower,
It does not show the measurement I need.
/ Question on iMatch #4
Is this what you are looking for? It's about 1 1/8"
That's it, Thanks
Horse Weather Vane (A64127)
Horse Weather Vane...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63689)
2023 Kubota...
Ford 3910 Tractor (A65579)
Ford 3910 Tractor...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
90in. Work Bench (A65640)
90in. Work Bench...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
