Question on iMatch
   / Question on iMatch #1
Gizmo2
Veteran Member
New York
JD 2320
I am making a rear three point hitch ballast. I have a steel plate that measures 30 inches across and will need to mount the lower 3PH pins in from the edges of the steel plate so that I will stay I-Match compatible. Can someone give me the distance I need to allow for the I-Match lower hooks to clear the plate? How far away do I need to mount the pins from the steel plate? I plan on using two pieces of 5/16 angle iron 4 inches long that will be welded to the plate for the pin mounts.
jdbower,
It does not show the measurement I need.
   / Question on iMatch #4
Is this what you are looking for? It's about 1 1/8"
That's it, Thanks
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
JOHN DEERE 4430H TRACTOR (A54756)
JOHN DEERE 4430H...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRK (A51406)
2014 INTERNATIONAL...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2018 KENWORTH T680 SLEEPER (A54607)
2018 KENWORTH T680...
UNUSED FUTURE VB59 - 59" HYD VIBRATING BUCKET (A54757)
UNUSED FUTURE VB59...
