Question on 2305 MCS
   / Question on 2305 MCS #11
I've seen the cart set-up. Holds a lot but limits your dumping options. With the bags at least I can drag them up to the top of the pile. And I did see a dumping option for some Deeres. It was a PDF file I found on-line while doing a search. I like the system Deere makes for the larger tractors. It will raise up high and then dump, so I can imagine creating a pretty large pile after a while.
   / Question on 2305 MCS #12
For what it's worth, I just got back from using this pulley to install my MCS. I think with practice this could make things much easier for me, but it will always be more of a feat of strength than a 3PH mounted one - especially with Pat's EZ-Hitch installed. Things to note:
I mounted it where I keep the MCS, you may be able to mount it on the ROPS but I don't know how difficult that would make installing the MCS because the pulley would be pulling the MCS forward whereas mine pulled nearly straight up.
The MCS is very lopsided from a weight distribution standpoint so make sure you mount the pulley over the center of mass of the MCS and not the center of the tractor.
I keep my tractor inside and I can just barely force the ROPS up in there (not an issue with a 2305 unless you have the aftermarket folding ROPS). If the ROPS is folded mounting the MCS is not likely to work for you, and even less likely if you're suspending it from ropes.
While the pulley is, shall we say, appropriately priced at $10 and I have no idea who would use it to lift 2000lbs, when I used it the MCS is easy enough to raise or lower with one hand while I guide it into place with the other. I bought four tow hooks to grab onto the MCS with - while they're overkill from a capacity standpoint they are able to grab onto the frame fairly well.
I never liked the tow-behind collection systems, and I'd prefer the 3PH hydraulic system but it's too big for the 2520 (officially, it apparently can work but you should have front weights installed). Of course, the ideal solution is to have a dedicated mowing tractor and just leave the system installed, but it's too late for that for me :)
Hope this helps!
   / Question on 2305 MCS #13
ChuckinNH said:
Jeff... this is the thread that mentioned the hydraulic 519 option. You might find it an interesting option......
http://www.tractorbynet.com/forums/...ny-use-bagger-collection.html?highlight=mc519
Funny thing is, just a couple weeks ago I posted on WFM that I would like to swap the gas strut for a hydraulic cylinder. It doesn't look like it would be much of a job. I shopped a couple of online hydraulic shops for an appropriate cylinder and found a couple that I think would work, but it appears to be one of those 1 to 1.5 tractor buck projects (a tractor buck is a hundred dollars -- no sense using all those unnecessary zeros) that gets put off for a rainy day and a few "spare" tractor bucks.
   / Question on 2305 MCS #14
To each his own, but hooking up my 519 cart takes two fingers and about 15 seconds. Connecting the chute to the PowerFlo takes another 15. The PowerFlo takes the longest, 'cause I usually put the belt on backwards the first time. :rolleyes:
Yes, the MC-519 makes a somewhat long, low pile. That just gives me a job for the FEL. Stir the compost pile and add the green grass.
Now, I gotta go send beenthere a PM.
   / Question on 2305 MCS #15
Well, beenthere got back to me in a hurry. His dealer, Midstate Equipment (6 stores in Central Wisconsin) makes up the hydraulic conversion kit for the MC-519. Only problem is the price, $480 :eek:
I'm pretty sure I found a cylinder that will work for about 70. Fittings for the QC are kinda pricey, but I'm pretty sure I can get the whole thing put together for under $200. I'll document it here and WFM when I get a roundtuit.
   / Question on 2305 MCS #16
I have the MCS on my 2320, and I just wanted to mention that you do not have to remove any of the 3pt hardware to install it. I also got rid of that stupid ring on the draw bar pin, and replaced it with a key pin (The way it should of been in the first place..).
Also, I had the MCS on my old 325 Garden tractor. It worked pretty good, but as it was mentioned on here it wouldn't do a very good job when things were wet. I replaced the JD blades on the deck with some heavy duty Gator blades, and it made a big difference. I'm thinking about doing this to my new deck.. Has anyone put Gator blades on there 62C or 62D??
   / Question on 2305 MCS #17
I've got a pair of Gator magnums due to arrive any day now for my 62c. I've used them before on a 48 and I think they're great. No MCS is going to work all that well in wet conditions. But the Deere powerflow has it's advantages over other types. A deck mounted impeller/blower breaks up the clumps right away and sends it up the tube. A rear mounted impeller as found on some other MCS units, is trying to suck the discharge into the deck boot and through a tube into the blower where it then forces it into another tube leading to the hopper. My NH CM224 had a deck mounted blower and it worked great. My Kubota F3060 and my Deere 1445 at work both have rear/side blowers and will clog easier. I've used my powerflow during a drizzle and wet grass many times this season already and if the grass wasn't so long while I was using it it wouldn't have clogged as much...but still I think it did a commendable job.
Thanks to eveeryone for their responses! I'm left with cautious optimism about the unit. It seems that it works about as well as the deck driven collector on my Simplicity, and though the installation could be easier, it isn't terrible. I've learned that a dealer not too far away has one installed on a 2305 on his lot, so I'll go take a look, and perhaps talk him into letting me see at least how the heavy hood comes off. I collect hundreds of bushels of clippings, and leaves off, and on during the year, so it is important to me.
Thanks again to everyone for their input, ideas, and help.
Chuck
   / Question on 2305 MCS #19
Let me know how those Gators work on that bigger deck... I'm just about ready to push the buy button myself. If I knew they would make the same improvment on my 62D as they did on my 48" deck with MCS, I would go for it.
   / Question on 2305 MCS #20
Chuck
You will need a couple 30MM 6 point wrenches and sockets, and a solid torque wrench
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2012 Harley-Davidson FLHX Street Glide Motorcycle (A55758)
2012...
2019 FREIGHTLINER CASCADIA SLEEPER (A54607)
2019 FREIGHTLINER...
UNUSED DIGGIT 72" HYD MULCHING HEAD (A54757)
UNUSED DIGGIT 72"...
UNUSED DIGGIT 10D-10 DRAWER WORK BENCH (A54757)
UNUSED DIGGIT...
