Question on 2305 MCS
/ Question on 2305 MCS #21
I just tried my new gator Magnums on my 62c. Mixed results. Sounds different under the deck. Leaves a few clippings, though light, on the surface. Quality of cut was as good as before. But the real noticable thing was it seemed a lot easier to dump the bags. They wer full and as heavy as usual. But Instead of the usual struggle to get the grass to empty out, it only took a little coercion and it came right out. the clippings looked were finer too. But this was the first cut with them. I'll have to see how they work out in more varied conditions.
/ Question on 2305 MCS #22
I might be worth it just for that... Like you say its a struggle to get the grass out half the time.. Let me know what you think after mowing a few times..
/ Question on 2305 MCS #23
jdbower
Is the mcs on your 2520 a 2 or 3 bagger or a mc-519?
I had a dealer tell me that the mc-519 absolutly will not work on the 2305!!!!
/ Question on 2305 MCS #25
/ Question on 2305 MCS #26
I have the 14 bushel 3 bag MCS and it works wonderfully but it does fill up fast with the 62D
John
/ Question on 2305 MCS #27
interesting he would say that when it is clearly mounted to a 2305 on their website: John Deere products for homeowners: Features for Attachment 3-Bag Power Flow Material Collection System
Following that link, that isn't a MC-519.
I have a MC-519 and, no, it doesn't work with the 2305 without modification. I had a 3 point hitch welded up to support the steel cart of the MC-519. The entire unit is offset a bit to the discharge side of the mower (62C in my case) so that the blower chute is able to connect to the MC-519 inlet.
My 3-point raises and lowers the MC-519 as I raise and lower the 62C deck. Since the 3 point exerts no downward pressure the MC-519 simply floats along the turf and goes up/down with any hills/valleys.
When I'm ready to dump the clippings I raise the 3 point and the MC-519 is now about 2 feet off the ground. Undo the top tension bar, pull the dump lever and the whole unit hinges open and the load slides out. No lifting and dumping wet, heavy, dirty bags!
Uses the same PowerFlo blower unit as the 3 bag unit, works a whole bunch better!!
Good luck -
Scott
/ Question on 2305 MCS #28
Do you have any pics of your setup Scott? Thanks.
/ Question on 2305 MCS #31
cast_and_blast
Spring has sprung and summer is here. Any chance of those detailed pictures.
/ Question on 2305 MCS #32
/ Question on 2305 MCS #33
Hey folks!
For you that wanted to make the MC-519 into a hydraulic dump trailer how about a 12 volt electric actuator 3+ or 7+ or 11+ stroke from Northern Tool
part numbers 125010 or 125011 or 125012.
Northern Industrial Linear Actuator 12 Volt, 11 13/16in. stroke | ATV Accessories | Northern Tool + Equipment
$140 for the LONGEST back ordered but on sale RIGHT NOW.
There enough power in these actuators to raise the MC519 cart? Anyone with experience using this on their MC519 cart?
I have a hydraulic cylinder to dump mine, but costs more than $140.
thanks
Mayrath 10 x 63 Swing Away Auger (A66408)
Mayrath 10 x 63...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
Skeleton Backing Plate (A62679)
Skeleton Backing...
